10th August Great Ocean Road Cruise
qikshift
 Share
  • Replies 238
Originally posted by Jamezilla
Hows aboout the Shell servo on Toorak Rd (near Chapel) in Sth Yarra?
Yeah, hell close to my place. Good Thinking James.
I can also get to the ATM there to get you your $$$ for the MAS T-Shirts for me an Leewah. But thats another story.
I'm up for meeting at the servo. Early Sunday Morning should give us a break from too much traffic also.
Plus is close to my house. Leewah could make the trip in about 12 seconds :)
This must mean that you are about 500-600m away from the servo. ;)
As Leewah eats the 1/4mile in 10sec :)
Interloper>>> im the other one who said that i was gonna meet in geelong... there is also a mate of mine meeting there but he accidentally voted that he was just coming...
Nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
hey guys, im trying to come along!
just working out work schedule and clash with church that morning... /embarrased.
but it's looking good so far, i'm down for meeting up with apache, skylineakt, yogi and stuff at glenny. and then we all meet with rob at chaddy or something as we head down to geelong. ?? so we can all cruise down together.
dunno... but it's still a week away, so i'll see as it gets closer.
apache, will your ride be ready in time?
Guest RedLineGTR
I'll probably wait at chadstone mc donalds on the princess hwy (dandenong road) most people know this place. Dont know if anyone else will be there but i'll set a time later after i organise some other thing with some others that wanna cruise too. if thats makes sence *shurgs*
Guest RedLineGTR
Theres some more people on the way down dandenong road that we are gonna meet but nothin solid has been organised time wise for now.
i'll most likely swing yur way rob, so i'll cruise up with ya.
just thinking what to do about bov's... i can't go over 2k rpm without it letting open a huge one, will be very annoying on the cruise... but don't got a stock one lying around... anyone got a spare stock one to lend me for the cruise or willing to sell me one for cheep cheep? :P
 Share
    • Vanos solenoid problems and basically all sensors die an early death
    • Yep, back in the day when you could pick up a Stagea RB25 NEO for $1,500 it was worth it. These days... just chuck your V8 or B58 in.
    • from my limited BMW experience: - they burn oil WTF (B48 FTW 170kW engine) - dump oil every 5,000km and you'll be ok.. until it drops a bearing and rebuild time. replace engine with B58
    • I would avoid the AWD motor in a RWD using a modified RWD sump and pickup. The way the pick up is positioned, you'll have oil pick up issues on hard acceleration on a track around bends. Even with a baffled, gated sump. I suppose if you don't race on a track and it's used for straight line activities or street use you might be ok.
    • They absolutely are, but the thing is, if you're only exposed to these circuits for a while, what I normally think is good driving suddenly isn't so much. I was a pussy at the Nurburgring (GP) entering corners at 180kph - the difference in the balance of the car suddenly becomes so much more pronounced and I'm still a bit regarded at left-foot braking - something I now practice on my commute. So the (dream) plan with the E90 is to make it a 325i Cup car. Whether I get there or not is another matter. In my mind the simplicity of having the NA variant and cost made it a bit more appealing. Plus, like mentioned above, I'm actually too much of a pussy for big power. Of course I f**ked up by not researching enough on the N53 vs N52, the latter being more robust without the DI system.  Suspension-wise on the BMW, and I've been reading the technical requirements for the 325i cup, basically everything except struts has to be standard - bushes are free. I figure you get about 5-10mm adjustment with the rear camber bolts which should translate to 0.5- 1.5 degrees of adjustment. So with coilovers, lowered at 30/40mm I expect I can dial out some of the camber from a drop and attain -1.5 to -2. If necessary, I could get the same effect as the M3 arms with some offset bushes. There is a limitation on ARB width to qualify, although I absolutely want to get either M3 ARBs (can't say sway incase I upset GTSBoy) or the H&R ones - both of these are the cheapest options. Like mentioned, M3 arms are on the way and I should have them fitted within the next week. How are the BC Racing coilovers btw? Reviews are mixed but I think for me they would be fine; a friend of mine uses them on his R34 for track driving and has nothing bad to say. I'm looking at these or the ST coilovers (German brand, new to me) as prescriped the in Cup spec sheet. They're both similarly priced and offer camber adjustment. It's fine but it really upsets my OCD. I've got a couple of options for dialing out the rear camber and keeping my ill-fitting wheels: raise the rear a little bit, say 5mm, that should permit -2.5 camber or drop the front to restore that slight bias of more negative camber up front (not optimal with the roads here). The next alignment won't be until at least next year and I really need to rebuild the rear subframe. For now, I'm not using it at all on the streets except occasional blasts through the German countryside. I was covering about 10k kms p/year in Japan, I expect this to now be about 3-4k. You could say buy better sized wheels, and yes, I should have. But the wheels came from the Z and price of good wheels is just insane now. Again, a couple of options: get a new set (I want 17" RPF1s) or buy two used 9.5J TEs, both are about the same price excluding shipping.
