was following a white R34 on narre warren north rd down onto narre warren - cranbourne rd with green p plate on rear bar and a very nice R33 comming out out laurdadale rd ( i think its it) with DAYMOE plates
Spotted a number of 33s around Dandy today... ...nothing too stand out really...
Saw a red 33 as I was pulling into my GFs place this afternoon... ...He flashed his lights at me and gave a wave... ...I returned the wave...
I think he flashed because I had my lights on... ...I tend to drive with them on most of the time...
also spotted a few r33 around dandy yesterday... a stock looking white one, a grey one and a nice burgundy one with personalised plates but for the life of me I can't rember what they were...we were sitting opposite you at some intersection.. I was in my mates r33 white one with r34 rims...
Silver S2 GTST on Riversdale Rd, near Camberwell Junction at about 1pm today. Think the plate started with TSN. Had SAU stickers on the quarters. :thumbsup:
I'm pretty sure that would have been me. I was just getting some lunch with the gf on our day off
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
