spotted white r33 turning right infront on hallam rd . chick driving dude riding shotgun
black r33 gtr plates start with WEA ### in dandy, parked
spotted grey r32 GTR plates (godzil1) or somthing. in dandy also, was gonna give you the thumbs up but couldnt see in the car
saw a gun metal GT-R or GTS-T might have been a GTS-T with GT-R front bar ... to dark to tell anyway i think it was gun metal or it was something like that anyway saw it on wells Rd driving past sexy land on the opposite side of the rd looked hot
Spotted a black r32 about to be towed on Shelley St, North Richmond near the new building - Seems to have broken down.
Silver R34 GTT coupe parked along Elizabeth st, North Richmond near the PKBA building.
R33 GTS25 on Cheltenham Rd this arvo at about 4.30 I think (don't know the exact time coz I put a new battery in my car and everything got reset!).
Looked like the driver was really enjoying the music being played in the car :down: He was getting really into it and banging his hand on the side of the car.
kspots08 dont recall seeing you, ahhh unless you were in the 32 in opp direction? :P
Spotted HIGRLS in narre today
blue 32 with black bonnet in narre @ fountain gate
orange 33 in kings park
RB25DET also in narre (I think thats the plates)
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
