spotted white r33 turning right infront on hallam rd . chick driving dude riding shotgun
black r33 gtr plates start with WEA ### in dandy, parked
spotted grey r32 GTR plates (godzil1) or somthing. in dandy also, was gonna give you the thumbs up but couldnt see in the car
saw a gun metal GT-R or GTS-T might have been a GTS-T with GT-R front bar ... to dark to tell anyway i think it was gun metal or it was something like that anyway saw it on wells Rd driving past sexy land on the opposite side of the rd looked hot
Spotted a black r32 about to be towed on Shelley St, North Richmond near the new building - Seems to have broken down.
Silver R34 GTT coupe parked along Elizabeth st, North Richmond near the PKBA building.
R33 GTS25 on Cheltenham Rd this arvo at about 4.30 I think (don't know the exact time coz I put a new battery in my car and everything got reset!).
Looked like the driver was really enjoying the music being played in the car :down: He was getting really into it and banging his hand on the side of the car.
kspots08 dont recall seeing you, ahhh unless you were in the 32 in opp direction? :P
Spotted HIGRLS in narre today
blue 32 with black bonnet in narre @ fountain gate
orange 33 in kings park
RB25DET also in narre (I think thats the plates)
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
