Ummmmmmmmmmmmm yea was on the way to pick up a BBQ with my mate in the work ute we say this and i creamed my pants .... lol just thought i would share !
Ps:Gotta love the Nokia 95 8G
Im sure thats the Aus delivered one that Nissan Australia has, they have a grey GTR aus spec in their workshop:) that they are doin their own evaluation on
Also a little late but spotted ROSIE 6 (33) a couple days ago on the Tulla and MRGTSR (33 4door) with a massive wang? on the tulla also
yea thanx man it was so random me of all people had to be next to it i love them i cant wait to buy one in the future and im on sau all day long i go for a 20 min drive and i see a R35 lol
I use to see a Black R35 GTR and Blue R34 GTR(still there) every day on Spencer Street in Prestige showroom, I think they sold it now....spot Skyline everyday...this morning White r34 on Footscray Rd looking good :D Westside FTW
Spotted in the office at work... ...grilled me on where I was last night... ...grilled him on if he's showing up on Sunday...
Are you gonna post up on the spotted thread everytime we run into each other at work or everytime you see my car in the carpark? Hahaha...
and yeah, i think I will actually go on sunday...but will YOU? As if, use your late night airport run to not attend...pfft...
wouldn't mind cruising up with a couple of skylines either to the show and shine if anyone from SE suburbs are interested...?
also...spotted a black R33 at dandy coles car park RBJ3T i think it was? I was parked next to you in my white 34 and exchanged a quick hello with you.
Nah... ...I wasn't going to bother today... ...but then while I was with my last client I was going to post another spot and saw Basti had spotted you... ...So I popped that up instead...
We could meet up at the office car park around 9am and head over if you like... ...Or... ...if others want to meet up also... ...Behind the Springvale Town Hall... ...
Now I'm off to bed... ...I'm tired and have this festy rash of pimples on my arm where a client touched me... :unsure:
saw a nice silver 33 gtst with uneek sticker on top @ chapel street
saw a dark blue r33 gts parked on chapel
another r32 at coles carpark - chapel street
lot of other nice cars
was the r32 black if so it was my baby went for coffee at around 10ish :ninja:
spotted a brand spankin new r35 gtr on the pakenham bypass heading towards pakenham yesterday as i was driving from work to my gf's house. Road registered and everything!
drooled and creamed at hte same time
Had a killer spot today near Kew. Had NSW Rego, driven by an older looking gentleman. He wasn't afraid to step on the loud pedal either. The gear changes sound amazing, seen them perform on videos but you don't really appreciate it until you see/hear the real thing.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
