Spotted that Stagea that has some whacky ass alpha numeric rego plate that might say STAGEA... or something.
In Clayton, near CAR-X.
yeah my bro seen that one also, he couldnt work it out, thought it said STARGATE or somthing
also seen a r33, but at first i heard a honda, then realised it was the r33 :S
maron one turning right just after westal off heatherton rd around 745pm
spotted silver r33 with plates CRZY33 , mate you need to relax, big deal its a r33 i see them every where, no need to speed up around a corner just so i can hear your exhaust. its no different to the next r33 i'll see 5mins later
lol.. umm nah u need to relax.. that was my boyfrend driving that day and he was driving normal just like i do...?
he usually drives his silver stagea and u have spotted us before on here... and by the way u of all people should live up to ur number plates anyways :rofl: haha
Spotted Bayside blue R34 GTT and Yellow R34 GTT at Arthur's Seat on Sunday. I was the White R34 Sedan
I was the bayside blue GTT..... also spotted same day a white 33 around Arthur's seat at the top was with a motor bike i think
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
