spotted few members of SAU in issue 75 of AUTOSALONN!! lol
i think i saw Bez leigh and Ashneel i think, dezz might of been in there too..only had a quick glance
as soon as i read that text i went and had to double check. SAU IN AUTOSALON MAG! :cheers: woo lol
Spotted a BLACK R32 GTR ( I think the number plate was MZTURBO or something close to it) on Sunshine Ave around 2-3pm
Then around 5pm ish Near That Auto shop at watergardens, it was a White 2dr R34 with GTR front and Carbon Fibre hood, LOOKS KOOL
Yeah buddy that was me haha, did u floor it after the lights when we ran?
Or where you just playing with me? hahaha
i cannot remember running you because i never went past vacume on my boost gauge lol.. if i did want to run u.. you would have noticed :D
was jst cruising along... dont remember flooring it after the lights either...
Hahahaa woohoo! two spots in one! MZTRBO was me :( and white r34 with the GTR front end was my old car
oh btw, were u the black four-door with diff rims on each side? u then turned off into the carwash and were washing ur car.
I was with my friend in the car we seen u turn onto sunshine ave and were both like at the same time 'the rims on that four-door look hot what are they?', then we caught up to you and the rims on the otherside were different lol
It's all the rage now. Haven't you heard?
As long as the tyres, offset, and diameter were all the same on all four I don't see why there would be a problem with having different rims on either side... ...Put a black set on the right side and a silver set on the left...
It'd be a lot easier to tell who ripped you off too...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
