Spotted Ashneel doing a knox lap :) then leaving knox watched a ford ute leave knox innapropriatly and stacked right outside the knox cop shop was quiet funny to see cops come running out.
pics or ban :)
spotted a chic driving a black r33 series 2 on the monash at around 6pm (city bound, and got off at heatherton rd exit)
Spotted Dane on the Monash near Warrigal Road yesterday morning while sitting in the car park Lucky you were going the other way....
Spotted a Nice back R34 this morning on the Monash joining at Forster road
See a white R33 decked out with carbon fibre hood and bootlid around Maribyrnong, near the river, quite often.
A custom paint-job R33 GTS-T plates [uBH***] cnr Western HWY/McIntyre Rd around 2:15pm today. Was sky-blue with bright green surrounds for the windows and tail-lights.
White R34 4-door westbound on Western Hwy F'scray around 2:45 pm.
11:30pm-1:00am in order
Yellow r34 gtt on chaple street with black wheels silver rim.
blue r33 with twin cannon's around the S bends.
JDMCOP r34 in Dandenong followed by a wrx or evo 3 couldnt tell. man thats an awesome looking car, like what your've done.
and a bunch of r33's black,white,silver. on the dandenong bypass, massive cruise going on tonight about 50cars easy i'd say.
spotted lukeb on stud road at around 12:40 today. gave a thumbs up but dont think you saw it lol :happy:
then at bout 1:10 saw a silver 2 dr 34 on stud, head towards stud/highstreet lights, nice kit...didn't catch plates
lol im trying to get her to sign up to the club but shes so damn lazy! lol :happy:
Yeah I have harassed her too. She was behind my mate at the C4C cruise to heathcote. Needless to say with the defect station on the exit, had plenty of time to get out and have a chat with her.
Spotted Ashneel doing a knox lap :happy: then leaving knox watched a ford ute leave knox innapropriatly and stacked right outside the knox cop shop was quiet funny to see cops come running out.
HAHAHA serves the dickhead right for being a hero
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
