Yep :P + black wheels with chrome lip.
Maybe that was you the other day lol. Woulda been last Wednesday or something, you were driving down lower dandy in the morning then you turned right onto springvale rd?
I was in my mums car again lol
Yeah, that would have been me. Wouldn't have been turning right though. I head down to Dandenong every morning for work :P
yeah headed back from work in burwood...dont worry im the same, i look for the CF garnishes on ur spoiler :(
speaking of work...theres another yellow 34 with eyelids and nismo kit where i work for telstra...noticed on friday it has SAU stickers in the traditional spot...anybody know who it is? lol
What part of Burwood do you work in?
I work there too :)
Spotted a clean dark coloured wingless R33 drive past me at the dalton road/western ring intersection whilst i was turning right back on the freeway around 11pm. And earlier around 8pm saw an red(??) MR2 when i was driving into plenty valley s.c. who gave me a thumbs up so i returned with a nod and thumbs up. Also see the gold R32 everytime i head into plenty valley. If youre on here ron, then g'day, not sure if that gold 32 is yours or your brothers car, but it's very nice. You might remember me from years back when my alternator let go in my black R32 around mill park and you and your boys helped me out, thanks heaps for that bro. Will send you an sms if im in the area again. :D
Hey mate it's me ron, yeh i still got the skyline just changed it to gold,swing past next time ur in the area.
Hey bro, next time i head upto plenty valley i'll pop by and say hello. Alot has changed on my 32 since the last time you saw it, will fill you in when i see you next. i've also ditched the twins and gone back to a single :D .
:) This hot azn chick in a white R34 sean with a CF bonnect and nismo front bar. I almost always see her daily in the Camberwell area. She never looks at me. Today she had a guy in her passenger seat - *Heart Broken*
UVH xxx plates by any chance?
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
