Spotted Kris's car in my dream last night :D Sadly it got written off because he was speeding and couldn't slow down in time for a red light.
Weird.
Fixed
It's true. I have sexual fantasies about Kris. Sorry Cas.
Did you CR33M you pants?
LOL
it's not the same guy, that "sweet track looking white 31" is mine :D ..I'm Esthers bf, was picking her up from work.
Lol... car looks good, i was on my way home from work and woulda stopped for a chat if you'd been with the car. goin to take a look at a stock 31 gxe on sunday which is sposed to be a cheap daily, but i've already spent half of today pricing up mods b4 i even get it... :S
Jesse bet me to it, but yes, the 31's his. Pop into my work sometime, i'm there pretty much whenever w're open. Just let me know you're the guy from the marsh ;)
haha, will def stick my head in and say gday some time mate ;)
Black or gunmetal R32 (couldn't see if GTR or not, too dark) Rego was TURBO6 on Swan St tonight at about 6:15pm going city bound just near the lights that take you over the train lines to go to the city link. I was in the silver 32 GTR sitting in the turning lane at the light, saw you too late to wave or toot.
Spotted JamesK's 33 at Monash Caulfield again :)
Man... so many people tried to squeeze their car in the spot right in front of your car and I just stood there and watched, in case if they did hit your car :(
hey mate, i think i see your R34 couple of times in monash caulfield. is yours an automatic and have number plates that starts with UAE ? i might have mistaken yours for another yellow R34
saw the yellow gts-t again going into caulfield campus monash uni.
Did you see mine this time or the other one that you saw last time? lol
I saw the other yellow again too!
And yes I go to Monash Caulfield, I'm there Mon, Wed, Fri.
I think its jamesk's , your cars looks so smiliar. which building do u go to? Im there everday if not thats because I skipped class. :)
i did saw urs Charles...mine is a black one with stripes=)
im in building B or C. I'll say hi next time I see u, that car in the signature right ?
Yeah, that's my car :( It's got SAU stickers on both rear quarter windows.
Did you? :)
Where do you park?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
