Haha nice to spot ya :down: nice rims.
Spotted myself at Melbourne airport about an hour ago with cops blocking the entire place and an uncovered dead body on the ground :P cops were taking photos of it. RIP
Edited by UnCo
Haha nice to spot ya :D nice rims.
Spotted myself at Melbourne airport about an hour ago with cops blocking the entire place and an uncovered dead body on the ground :D cops were taking photos of it. RIP
Yeah, i like the rims but the other day i was shocked when i saw an exact white r34 skyline with the same rims... :)
And i passed near the airport today too, massive crash on the other side of the freeway... didnt not look good...
heh, I was almost about to appologise for that except that he would have just as much chance of getting booked on the road and police can't take this as concrete unless I confirm as a witness.
If he drives like that often he's going to get booked anyway. *shrug*
I thought that was what cool plates are for :3 If I get plates you have permission to post them!
I saw a Silver R34 a few months ago on the westerning road and he had a Thor MX sticker on it, I luuuurve Thor MX except there was an old man driving it... thought it might be his sons. If anyone knows the person or see's it again let me know, I think they are my sould mate :P
I think you did right by posting the plates up!
got to be aware and keep track of pple who drive like that.... :P
ps: i am dying to be spotted... someone!!!! :)
I spotted you on saturday, at the GOR, i was sitting on your tail the whole time.
posting plates up here isnt going to do anything, if that person is doing something wrong then so be it, the law will catch them eventually
this is a spotted thread, not 'dob in a hoon'
on that note, saw a black 32 gtst down glenferrie,hawthorn today at 11am
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
