Yeah that was me, I saw you go past with some other cars after lights.
Most likely me, I drive that way every day :D
Never seen your car, though.
Yeah, I've seen you going that way many times during weekday mornings. A lot of the time I'm either driving behind you or see you at the lights waiting to turn :touch:
And a lot of the time, I turn onto Princes Highway going your direction at the red light camera just before where you turn off.
haha cheers man got some more exterior mods going on this week as well :rofl:
and yeh for sure if you wana come for a spin ;)
What you got planned? Or is it a secret? :(
I'm down your area all the time so if you're ever bored let me know ;)
