Spotted THOR65, a LHD 1965 Ford Thunderbird convertible being driven down the Monash outbound around 11:30PM, exited Blackburn Rd - driven by none other than Sam Newman. Must be going to Sandown or something today?
And saw a black R34 sitting behind me at the lights on Dandy Bypass and Frankston-Dandy Rd around 12:00. You changed lanes multiple times to get behind me to do the traffic light GP, typical abortion of traffic in that area.
Headed down to Fentree Gully today and spotted so many Skylines :O Quite a few up that side o' town!
The only ones i can remember were:
Spotted [ ODIUM ] white R33 (I'm pretty sure hes on here) round 4:40pm pass Nunawading KFC lol. and another white R33 parked a few kms down the road which had a black boot.
Spotted a white R34 near Heidlburg NMIT about 5pm
Spotted another R34 near Rezza station about 5:30pm with a bodykit and D1R rims........I Ruv D1R Rims :wub:
Spotted htial on Edithvale Road around 1 or 2pm today! Nice decals, very eye catching!
I was on Edithvale Road???... ...Really???... ...I was lost there for a while...
What were you driving???... ...And you must have passed on the drivers side... ...Decals are all gone from the passenger side...
Came up to you on the driver's side on Springvale Road near the Frankston Freeway, noticed the skyline first, then the decals and then the club sticker. I turned off right onto Wells Road and you went straight onto Edithvale Road (Springvale Road becomes Edithvale Road at the last 2km approaching the bay). I noticed some of the decals are peeling, but it still looks good!
I drive a gold CJ Lancer, mostly stock so nothing all that exciting :P
Edit: formatting
Edited by Longinus
Ahh... ...I see... ...Then let me update my last post with "Spotted WANZI parked on Edithvale Road"... ...Sorry I didn't see you... ...I was too busy looking for Skylines... :thumbsup:
hehe no problem, seeing your sticker reminded me to finally register here :P
There are always a bunch of skylines on Edithvale Road or behind the reserve along Fraser Avenue going down Hughes Avenue. Don't know them, but see them all the time as a friend lives there.
Can also add to the spotted list, a blue R33 with the plate N1T1N on Park Street in Mordialloc. Pass it everyday on the way to/from the train station before and after work! :D
whos the white r33 who pulled in the maccas off western port highway then legged it when he realised there were cops there haha
Hoon tow????
and the he may actually be a she...
Should have realized two tow trucks at midnight in one spot didn't mean free mcdonalds...
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
