Spotted Snowy's R35 tonight. felt weak at the knees, first time in the flesh with one
sorry buddy never met you so didnt know who was who, my rudeness :D
burgandy r33 pretty stock at parkmore shopping center TOK-***
black ? r33 with aqua front bar and missing grill also in the same parking lot, just though i should of put cards on ... too late
Spotted a Holden Barina at Fountain Gate...
WITH A CANNON!
Fail :bunny:
Hey, you think that's bad?
Earlier in the week I saw an Astra with a QUAD CANNON! :D
Oh, and spotted: Purple R34 with clear tail lights in Dandenong today.
2230: White R33 on Punt Rd. Came up beside you as you were turning off into Bridge Rd.
Clean but someone has to teach me the difference betrween S1 and S2 rears.
S2 rears generally have the skyline garnish painted the same as the body colour, S1 are just clear like the indicators.
other than that ;)
spotted 2 r33's last night at knox parked outside timezone. a silver one and a red one. the silver one was about to leave but a cop rocked up behind it and it stayed there until it was clear haha and then when it left the exhaust vibration set off the red R33's alarm.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
