Can i have a Power Estimate for the following mods on an ECR33 S2 RB25DET. Like how much HP or kW can i get if these mods are done and tuned properly on power fc.
Stock RB25DET Internals
Stock AFM (Nismo didn't make a version for the ECR33)
HKS GT2530 Turbo Kit
Nismo Fuel Pump (4.1L)
Nismo 555cc Injectors
ARC Front Mounted Intercooler
SplitFire Coilpacks
Nismo Muffler
Nismo Sports Clutch Plate, Nismo Sports Clutch Cover, Nismo Lightened Flywheel (can hold 380ps aka 280kw)
Edited by teng
https://www.sau.com.au/forums/topic/210885-power-estimate-ecr33/
Z32 AFM Hmmm. I always get the impresion that the ecr33 and z32 AFM are the same. lol I'm guessing that the Z32 AFM is a direct bolt on (no wires to splice or anything). How about a Z33 AFM ?
Edited by teng
Anybody knows what a Z32 AFM looks like? When i say 'looks like' i mean serial numbers or something that tells me it's a Z32 AFM. The local wreck yard is a mess and they just dump all the AFM in one area which makes it hard to find if you don't know what you are looking for.
Anyone knows where i can get a 'new plug' for the Z32 AFM?
220-240kw isn't much. I was hoping for at least 400Hp aka 300kw or around that number :)
Ah yes, i forgot to mention adding a Nismo Single Plate clutch & Lightened Flywheel as well.
Edited by teng
my impression would be if you were wanting to hit 400hp with that turbo, it would be either unarchieveable or fairly close to it and ya turbo wont last too long.
if you were wanting to hit those numbers then a gt3040, gt30r, gt2835 would of been a better choice.
I am hitting 344hp on 14psi with a gt30r, so havent really started getting into the efficiency range of my turbo yet. So 400hp is easily archieveable if my engine holds up.
Get a z32 afm, or a q45 afm, stock afm wont cope after 240kw.
also get a full turboback exhaust
nismo muffler sounds like you have the std exhaust system - if you do, throw it in the bin
You might want to keep the stock exhaust for defects :no:
Definitely get an aftermarket exhaust system, headers, and consider getting a high flow cat if your going for a turbo upgrade. The better the car can breathe the better it will work.
Also consider a high-flow panel filter (that ones debatable though) if your running an aftermarket airbox.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
