  • Replies 1.9k
I assume type is either the variant (ie GTST) or they mean street/race. actually they have type twice so the first one would be variant. as for log book you don't have one. obviously if your car is logbooked then you would put the number in. only applies to cams log booked cars.
Hi Guys,
That form on the site is only a form to get your name on a spot. The official entry form is on its way from cams and I am hoping to see it by the end of this week *fingers crossed* The car type is ust referring to GTR or GTS-T and car group is which class you want to run in.
Cheers
-Nathan
Have you guys given thought to the spectating aspect and all that it entails yet Nathan?
The line up for both classes at the moment looks awesome and I'd love to see some of these cars getting around the track.
Maybe if this sort of thing takes off I might have another reason to help me convince the other half to let me modify the unregistered hunk of metal in the garage :thumbsup:
I'd just need to find the money first! lol
Spectators are welcome it will be $15 at the gate.
Cheers
-Nathan
Clubsprint Class can only use street tyres.
Time for everyone in the street class to go out and get some Federal 595RS tyres. Last time i checked they weren't in the cams book as a R compound semi slick so still a street tyre :banana:
Which (to my mind) shows up the fundamental problem in forcing people to run "road" tyres. They end up having to buy new (shit) tyres to be anywhere near competitive, thus negating the whole point of the exercise.
Anyway. Good luck & go the Porsches. Eh?
595RS are on the list of tyres you can't use on the website.
"All vehicles entering the Superlap Clubsprint Series must run on S compound tyres. Tyres that are exempt from Clubsprint class are show on the Superlap Australia Tyre List. Click Here for the Superlap Australia Tyre List. Tyres which are also exempt from Clubsprint Class that are not shown on this list are Hoosier A6, Hoosier R6, Kumho Ecsta V710 and Avon Tech R-A."
If it comes to Sunny QLD can I suggest it is held somewhere other than Queensland Raceway, such a bad track for a well balance car. It's a power bore-a-drome in my opinion. Options of other tracks are limited I know, Morgan park would have adequate facilities, I don't know of any others with pit and gararge facilities most top end competitiors would want.
Want to win, buy new tyres. Want to have fun, show up and have fun...
Rear engined 6cyl cars are disallowed if you read the rules so goodbye porsche
Nathan,
Any plans for an event in sunny QLD destined for the near future??
Yes we are hoping to run one in QLD in the near future so long as this first event is a success
We are going to narrow down the tyre list for Clubsprint Class very soon we just have to sit down and discuss it.
Cheers
-Nathan
Edited by Superlap Australia
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
