Hey Guys,
Here's something I thought you'd all appreciate. Driving up the coast to Byron Bay, happend to come across this parked on the side of the road in some small town - middle of nowhere! What are the chances! Stalked it for a few hours on the highway then stopped to get a better look. No one knew what is was though! All just casually driving past. Idiots. Only two in the country atm, or so I was told? what a privilege. Wish I owned Donut King :thumbsup:
Enjoy,
Courtney.
Edited by Courtney
https://www.sau.com.au/forums/topic/211404-r35-gtr-spotted-in-nsw-country-pics/
talk about luck
do I spot titanium exhaust?
we should be proud, we are probably the second GTR in the WORLD to get a new paint job so quick out of the factory
Yes. Titanium. Caressed by my humble finger :thumbsup:
yeah, they're almost as many 35's in the country as commondoors :(
what the hell is it doing heading UP the coast? Didn't anyone tell them that Tassie is the other way. "mate you need to go this way :) "
I cant wait to see it race.
I can't wait to race against it
As if anyone even eats at donut king anymore, that food is shit and toxic, surprise they turnover enough to run a car!
Thats a pretty ignorant thing to say
wonder how it sounds.
+1
Id take a punt and say its going home to DK HQ b4 Targa, which is still a few weeks away
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
