  • Replies 64
I think they supply a spacer/adapter plate for the 3071r
but they have a 2871r that they say is a T3 direct bolt on, with only adapters for oil and water required.
http://www.tweakit.net/shop/product_info.p...roducts_id=6596
i thought the garret's didnt come in T3
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3738207
Obviously they have sourced reproductions of the RB25 and VG30 housings, mating them up to Garrett cartridges. That gives the advertised 0.63 and 0.71 A/R.
GCG and HPinabox are doing similar products.
Simon-R32 is running the 3071, which comes with the 56.5mm cropped version of that turbine. It also has a 0.5 A/R comp cover, which is big enough to flow 280 rwkW. I would suspect that the larger 0.70 cover used by tweakit is being used purely for underbonnet bling and it will necessitate the use of a spacer plate for the turbine mounting just to get clearance from the manifold.
I ran a 2871 hybrid similar to the tweakit version. Not hard to fit up, and gave plenty of responsive poke.
FWIW, those power claims each seem a bit high. But they'd likely do a pretty good job for the money. Just another option out there in the market.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3738455
that appears to be the exact same turbo that i got from GCG. if thats the case then you'll expect excellent performance from it, its not laggy at all and can make the numbers! Mine is making 280 rwkw atm on 17 psi
Does yours have the 1.06 exhaust housing, when does it hit full boost?
I have contacted them about this, apparently it is a garret housing.
dont forget to add the fitting kit (the option is down the bottom) which will cost you an extra $680 to make it a bolt on.
i am looking at getting one of these after i have rebuilt my engine.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739616
The sum of the parts of the fitting kit doesn't equal the $680 price tag. The base turbo is certainly cheap, but once you add in the fitting kit you may as well talk to your local turbo supplier as the price will balance out.
Just a word of warning for the uninitiated: The specs listed for that turbo are not 3071 specs. If you want to see the proper specs then go to www.turbobygarrett.com and look up the 3071. It lists both the cropped and uncropped versions.
I have no idea why you'd want to run a t04s comp cover on a 3071. The fact that it's listed with a .7 cover makes me think they either don't know what they are listing, or they have mislabeled the turbo. The one in the pic is a t2 flanged i/w version of a 3071 though. 550hp is a bit optimistic as well.
the .71 turbine housing is most definately not a genuine garrett unit, though there's nothing wrong with them if simons results are anything to go by.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739748
No mine has the .71AR rear housing. full boost at around 3500 rpm. sure its a cropped turbo, but my results and findings have been in several threads now... its a good turbo
if i were to do it all again i'd go a proper 3071 hands down.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739774
whats a proper 3071 then? cause il be buying one real soon.
if its a non genuine garrett unit with the .71 rear housing what are the right specs.
would i be better off going for the 3076r? as i am looking for about 280rwk on 16-17psi or so.
Edited by R33GOD
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739907
I spoke with HP/box and there version of the 3071 has a .50a/r comp 56t wheel but the exh a/r was a.73 which they custom build and he couldn't even remember the exh wheel size/trim which leads me to believe it's the cropped one, but overall it seems like a good turbo, bolts to the stock dump and manifold with a 10mm spacer, oil/water lines need making.
Edited by turbomad
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3771936
I am about to organise a group buy through garrett for a bolt on kit they designed for the RB25
I have the prototype on my car making 295rwkw.
The kit is a direct bolt on and is also rated to 550 hp. It will also come with a dump pipe.
Cost is in the ballpark of $2500. Makes full boost (18psi) by 3100 rpm.
Do you guys think there will be much interest?
Min purchase is 5 at a time. I have sold 2 already, if I get another 3 interested the group buy will go ahead.
Obviously more specs will be posted if there is any interest.
does it come with the fitting kit?
im assuming it is the same turbo as here http://www.tweakit.net/shop/product_info.p...roducts_id=6598 and that one with fitting kit would still come in under 2500 delivered.
is there a difference between yours and theres and can you do a better price with out the dump pipe as most people want one of these so it will bolt up to the dump pipe they already have.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772059
I'd be interested to see whats in the kit.
All installed inc fabrication of new intake piping (which is incomplete, no bov or bov return atm), new dump and front pipe, turbo, lines silicone joiners i didn't already have lying around, spacer, new studs, gaskets, nuts i reckon ball park 2900 cost all up, 3k if you do the head/manifold gasket.
edit, you posted while i was typing. stock lines would save 250 on their own, though i'd be interested to see it. how do you get around the spacer issue with stock lines?
Edited by BHDave
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772082
i'm interested in seeing more ever since you originally posted the results trooper.
interested in whether this ends up being a 52 trim 76mm compressor when someone pulls one apart.
if they are a bolt on and your results are duplicated they will sell like hotcakes.
+1 for interest here
Edited by wolverine
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772097
Trooper ages ago when I asked your contact he said it had a sleeve pressed into its turbine housing which was re-profiled to suit the cropped GT30 UHP turbine . At that stage the proper Garrett petrol spec GT30 IW T3 flanged turbine housings had been not been released so at times less than perfect alternatives were being used . He did quote its Garrett BB CHRA number and I don't recall which one it was other than it had the cropped turbine .
The real GT3071R can be bought or I should say ordered with the designed by Garrett GT30 turbine housing and you'll know its a complete factory matching assembly . Not machined or altered in any way other than its original design parameters .
To make a real IW GT3071R kit for an RB20/25 is straightforward . The water and oil fittings are the same for any GT BB Garrett turbo from GT2554R up to GT3582R because they all use the same bearing housing .
One you have the spacer and fasteners to get the compressor housing off the exhaust manifold all that's left is the air in/out plumbing and the exhaust outlet pipe .
I'm surprised that at this stage no ones made jigs and produced dump pipes to mate a GT30 IW turbine housing to an R33's engine pipe . The genuine GT3582R IW turbine housing uses the same outlet flange dimensions so such a dump pipe could easily cover the whole GT30R/GT35R range meaning the real GT3071R , the real GT3076R and the GT3582R . You could buy it once and know it suits turbos from ~ 420 - 650 horsepower plus and bolts straight onto an R33 RB25DET with any of these turbos .
Anyhow Trooper I don't know if the turbo you are talking about is the same as the one you had when we last spoke but if it is there are issues with non factory turbo components if they need to be replaced at short notice . One down side is that it chains you to the mob who produced it and if you fall out with them or can't reach them its a bad outlook .
To each their own , I'm waiting for the results of the real GT3071R with the genuine Garrett GT30 IW 0.63 A/R turbine housing on an R33 RB25DET . As an all rounder for your typical R33 driver I think it should be pretty good .
Time will tell , my opinions only cheers A .
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772145
Trooper I think that if Garrett Sydney want to generate some interest they are going to have to show what they're offering or it all remains a mystery , and many perceive mystery to be risk .
I know there is also risk involved with copying and undercutting but once there are a few sets in circulation the cats out anyway .
I'm mildly curious to see what they've come up with but it would have to be something pretty effective and convienent to separate me from my money .
Over to you , cheers A .
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772801
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
