Does removing the hicas on a gts4 affect the 4wd system at all?
I was about to install my lockbar when I was given some information from a mechanic that it may interfere with the 4wd operation. Something on the lines of; the hicas operation being taken into account when calculating the amount of torque to transfer.
I thought the only method for this was comparing the front to rear sensors.
Anyone know the dealio?
https://www.sau.com.au/forums/topic/211531-gts4-hicas-removal/
Hicas removal won't kill your 4wd unless you do things like removing wheel speed transducers / wiring / etc.
What you may end up with if it isn't done correctly is quite heavy power steering effort.
Search for info on gtr's removal process and problems that occur as the gts4 and gtr are the same.
100's on here have removed their's, non have affected ATESSA that I’ve read about.
Some have heavy steering.
- SydneyKid says that a small change of castor (?) offsets the heavier steering.
- Someone on here modified the PS rack solenoid with a solid flange, to make it permanently light.
- The Tomei kit has a box you splice in, (along with the locking shims) that stops the dash HICAS light from turning on, plus giving factory like PS assist control.
I slapped a lock bar on, removed everything but have yet to drive it. I want to keep proper PS assist on my modern (modern'ish lol) import, so I figure I'll just splice the Tomei black box in if its an issue ($100)
My cents
I'd place bets that the tomei box is just a load simulator so that the hicas module doesn't see the difference. If I wanted to rip mine out, which is a long way down my list of priorities first of which is getting it moving again, I think it would be quite easy to replicate.
You can also wire the soenoid to a constant 12v, as long as it doesn't burn out it will give you permanent light steering, probably not what you want at 100+ though. Easier to build a pwm solenoid controller with a dial on it so that you can adjust steering weight for your wants.
I've only experienced the heavy steering problem when the
car had HICAS ECU problems.
From what I understand you can bypass the HICAS solenoid
in engine bay that sends fluid to the rear of car. This
supposedly bypasses the part that can cause the steering
to go heavy.
Also from what I remember there is a tutorial on SAU forums
about how to bypass the HICAS solenoid in the engine bay.
Edited by SKYPER
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
