Hi all. live in an apartment, therefore its parked in the open at nights. There was a holden stolen from the carpark yesterday in broad daylight..... so its made me extra cautious about my baby!
i have a mongoose alarm in my car, and a steering bar thingy. plus i unplug the coil loom every night.. i want to disable more circuitory.. eg starter, fuel pump..
if i unplugged the CAS, would the motor start at all??
i want to disable the fuel pump and starter too.. how can i do that??? sorry im just really paranoid since my cars the "most eye catching" in our apartment....
any help woudl be much appreciated. :P thanks
https://www.sau.com.au/forums/topic/211878-disabling-car-anti-theft/
look into getting a kill switch installed...
got one done for the fuel pump, simple on/off switch hidden away where the diagnositic plug is kept, just under the steering wheel to the right...
pretty sure most auto electricians can do it...
another way to piss any thieves off :P
there are already two topics on this in this section of the forum...
http://www.skylinesaustralia.com/forums/Ki...ch-t206288.html
http://www.skylinesaustralia.com/forums/Ex...ty-t206433.html
perhaps those may help... or if ur a bit clever and patient, design and build ur own...
Just add a little twist to the " Kill Switch" idea. Use a reed switch.Mount it anywhere behind plastic ( dash, etc.,), where it can't be reached by hand. You know where it is, and you switch it with a magnet from the outside. You can, with 2 or 3 relays make it so the magnet only needs to 'close the switch to start with. then it is OK until engine switched off. So the car is auto disabled as soon as it is switched off. You can kill ignition, fuel, whatever you want ( or boyh together]. Depending how neat you do the wiring, so it's not physically obvious, it'll take an Auto/lec all day to find it.
Get reed switches from security installers - used on building alarm systems. Or electrical wholesalers.
or perhaps get some from work :P
that is actually a really good idea... now im thinking... u could also use a coded magnet... unless u have the specific magnet and sensor, uve got no chance in starting the car... we use them all the time at work in our machines...
Link to full instructions
http://autospeed.com.au/cms/A_107975/article.html
Yes, that's good. Glad I did'nt know about it. That way I did the circuit myself ( without the kill switch) I like mine better.
I'll dig out my circuit and try to post it. Love the 'coded magnet' idea of the previous post, BUT don't lose it!!
No, can't do it. Am better at wiring diags than computers. Scanned it into computer, but can't get it from there to here. Sorry.
once its scanned, save it as a jpg file or something... when u post again, look down and right and ull c a "Browse..." button. click on that and find the file u saved. click ok. click the green "UPLOAD" button and wait... thats it...
yeh "kill switch" is kind of a wrong name... should be something more like "start switch" or something...
Edited by gumflapper
Thanks, I tried. Tried all sorts of places to scan it into, but got " X Upload failed. You are not permitted to upload this type of file." Had a good look at it ( even upside down) STILL did'nt look pornographic even from that angle. Guess everyone will just have to use their imagination. Pity.
"type of file" refers to the "filename.***" the *** part is the file type. jpg, doc, txt, mpg are file types... probably the most common image file is jpg. when u scan the file, save the file as "image.jpg" if u can...
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
