Hey guys,
I entered this $2 charity raffle, and the prize is $80k in 1 or 2 cars (it said caravans and boats too, but screw them). The 80k has to be inclusive of on roads and stamp duty.
What would you guys get?
If I kept the cars, I'd probably think of getting:
* 350Z track
* WRX STi (but insurance would prob be too insane)
* Lexus IS200 maybe
* still thinking.
or.. plan b
* buy any car which holds value really well and sell it the next day and take the cash (maybe 70-75k)
I have 1/600,000 chance of winning - wish me luck!
.. what cars would you guys get?
Lol, I enter this all the time! havent won yet, but Ill keep trying!
whatever you dont take as car you get in gold, so you can melt it down and turn it into a big turbo and manifold to fit it :)
Those "raffles" are so dodgy...
The prize is what 80k.. but if you check how many tickets they sell, they probably nett $500,000, give $250,000 away to charity, $80,000 to you and keep the remaining $170,000 in "administration fees"...
Just like in that 60 minutes thing about the Red Cross Bali thing with the RC keeping 1+million for "administration fees".
Originally posted by hippy
get 4 32gtrs .. then u can race all your friends .. makes for best weekend parties  :(
Even beta get 8 civic hatch backs for 10k n play dodgem/bumper cars wit em, how fun would that be?
or u can jus get a 350Z!!!!!! which i would prefer =)
Buy a Merc, sell it the next day. If you're going to keep the car, don't worry about the 350Z or WRX (i personally don't think they're worth the hype). An E36 M3 is beaut, or a second hand 911 Porsche, or a second hand RS4 Audi wagon (can burn most Jap imports), or 1/500 of a new Enzo, or a field of 120Y Datsuns. :(
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
