Hi,
I haven't logged on here for a while since selling my 32 GTR and getting into a FD RX-7 but have a trip to Japan booked and would like some assistance.
I am planning to get myself and gf to Fuji Speedway for the D1 practise day on April 26th from the Prince Hotel in Shinjuku, 2 minutes walk to Shinjuku Station.
http://www.fsw.tv/english/access/railway.html
Is there anything I should know about catching the Odakyo Romance Car to Gotenba Station and then Taxi to the Speedway? Is it really as simple as getting to the station and finding a cab?
We will have a JR Rail pass for our fortnight stay.
Any help would be greatly appreciated!
Regards, Jonathan
https://www.sau.com.au/forums/topic/212240-japan-trip-looking-for-some-advice/
the first thing i recommend is catching the odakyU train line...
directions from the prince hotel... turn right out the front door and walk straight to the main street ahead of you. Turn and walk under the bridge.(The JR / YAMANOTO train bridge) at the traffic lights cross the street (on your left) walk straight up the footpath(pushing through all the people) pass KFC , Yoshinoya, Cocos curry, cross another small street(walking straight) pass the big eletric goods store.... keep walking straight and go in the odakyu line entrance(on your left... and follow the signs. EASY
someone please continue from gotemba(??? station)
Thank you, Akeenan!
There is a bus timetable from Gotemba Station to the Speedway on the FSW site so that may be all I need.
We are spending 6 nights in Tokyo and then 6 nights in Osaka from the 24th April -6th May. Doing day trips to kyoto and othe surrounding areas of Osaka if anyone has any other suggestions.
Thanks again.
akeenan has it pretty covered. from gotemba i have previously just taken a cab. it wasn't too bad. maybe 4,000 or 5,000.
just follow his directions and don't fall into the trap of going to the closest entrance to shinjuku station (east entrance). you want to be around the other side, and your JR pass wont be valid on the odakyu line.
Thanks, will just have to see how well we go on the day.
I got a taxi from Gotemba. Good view of Mt Fuji on the way.
Yoshinoya FTW!
Getting a taxi from Fuji will be a little harder.Just ask someone at the front entrance,they will be more than helpful.
ya... nuh dont expect to see turbos intercoolers and power fcs there..
if you're after simple stuff like air filters, nismo clear indicators and some small nismo parts then they'll have it
go there if you're desperate but can't really get out of tokyo, or otherwise chiba's the way to go.
super autobacs actually have a good range of subaru parts on the shelf though, dont know why they only bothered with the subies
Consider hiring a car to get to Fuji.
I did and I got to see so much on the way. Also went up the top of mount fuji after and had a blast.
Drove around the mount fuji complex. ITS A HUGE PLACE !
Walking around it would suck, specially going from track to track.
By the time you pay for train tickets there and back. Then taxi ride there and back your costs will be close to a hire car + fuel.
You won't get to see anywhere near as much and you loose so much time in travel.
I am aiming to go to this too! want to meet up? I'm thinking of going down the hirecar route if you want in.
also I will be in osaka around the same time
Edited by Sarumatix
Most Train stations have English signs so it won't be too hard. They also have colour coded train lines. It should be fairly simple... you will get the hang of it quite quickly.
You must got to Super Auto Bacs when you are there. There is one near Tokyo. It is the Bunnings of car parts!!!
Nissan showroom is in Ginza (Tokyo)
If you drive up Mt Fuji don't get out until you get to the top. There are a lot of bears! At the top there are shops with military grade fencing behind it.
Kylie
Ding ding dong..."....Welcome to the Hikari Supa Express bound for Yokohama, Kyoto, Shin-Osaka... There are smoking trains on cars 3 and 5........"
Catch the Subway to get to Ginza for the Nissan showroom, and not the JR rail. Also walk a few blocks and find the other nissan showroom in Ginza.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
