The 3.4 should be very interesting, did you stick with 86.5mm bore and what style/shape of rod did you chose?
I presume you've made it so its a drop in kit for a stock block?
Rob
Edited by R.I.P.S NZ
The pistons are 20 thou over so ( 86.5 ), they will also be available in 40 ( at some point ).
The rods are a custom H Beam.
Drop in kit for stock block is the aim :-)
Cool, what is the actual cc rating with the 86.5mm bore?
Rob
pffft. whatervaa......... just anticipating someone thats prepared to spend 6k on a rotating assembly might want oil squirters. not me but im not everyone.
just have a japlish disclaimer, oil of the squirter instalation faliure...
I have never had a RB26 in the 240z, its always been a RB30, stock block, stock crank, RIPS wet sump etc and anyone who says a stock 30 crank won't rev hard or is limited to 7500 etc is talking rubbish
http://nz.youtube.com/watch?v=nHLfRseF_F4
http://nz.youtube.com/watch?v=G6qtA0_kQUc
9500-10,000 rpm during burnout
Rob
everytime i see this 'cocaine' car on the strip i get goose bumps - sounds better than a moaning hottie :blink:
to get a comp ratio here is 1 formula i work with
bore x stroke (bore =86.5mm stroke =95mm)
86.5 x 85.5 / 4 =1870.5625
1870.5625 x 3.142 x 95 = 558344.2006
558344.2006 / 1000 = 558.3442
litres
558.3442 x 6 =3350.0652 (the cubic centremetres of the block)
3350.0652 / 1000 = 3.3500
Deck height
i wont be running one but the formular is the same as the bore x stroke formular just replace the stroke with the deck height measurement
Head Gasket
I HAVE NOT REMEMBERED A MEASURED HEAD GASKET THIS IS A ROUGH GUESS
similar 2 the bore x stroke just replace the stroke with the squashed thickness of head gasket and measure the bore of the gasket, or could always CC it with a burette
i.e
87 x 87 / 4 =1892.25
1892.25 x 3.142 x 0.9=5350.9045
5350.9045 / 1000 =5.3509
Head CC
mines 62cc's atm
Piston dish/dome
if i get the kit id run a 12cc dome
add deck height, head gasket, head cc's, piston dish cc's (minues if dome)
0 + 5.3509 + 62 - 12= 55.3509
add the bore x stroke with the above
55.3509 + 558.3442 = 613.6951
devide answer with the above
613.6951 / 55.3509 = 11.08
11.08:1 is the compression ratio id be running
congratulations rob!
and u have this car for sale!? why sell such a beast
I want to get into something lighter, its about 200kg over weight for the Pro Import class I run in but I don't want to strip it out to be a full race car, as it is, it still has glass windows (except doors), steel hatch etc, just needs headlights and wipers back in and its road legal again for someone else.
Rob
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
