The 3.4 should be very interesting, did you stick with 86.5mm bore and what style/shape of rod did you chose?
I presume you've made it so its a drop in kit for a stock block?
Rob
Edited by R.I.P.S NZ
The pistons are 20 thou over so ( 86.5 ), they will also be available in 40 ( at some point ).
The rods are a custom H Beam.
Drop in kit for stock block is the aim :-)
Cool, what is the actual cc rating with the 86.5mm bore?
Rob
pffft. whatervaa......... just anticipating someone thats prepared to spend 6k on a rotating assembly might want oil squirters. not me but im not everyone.
just have a japlish disclaimer, oil of the squirter instalation faliure...
I have never had a RB26 in the 240z, its always been a RB30, stock block, stock crank, RIPS wet sump etc and anyone who says a stock 30 crank won't rev hard or is limited to 7500 etc is talking rubbish
http://nz.youtube.com/watch?v=nHLfRseF_F4
http://nz.youtube.com/watch?v=G6qtA0_kQUc
9500-10,000 rpm during burnout
Rob
everytime i see this 'cocaine' car on the strip i get goose bumps - sounds better than a moaning hottie :blink:
to get a comp ratio here is 1 formula i work with
bore x stroke (bore =86.5mm stroke =95mm)
86.5 x 85.5 / 4 =1870.5625
1870.5625 x 3.142 x 95 = 558344.2006
558344.2006 / 1000 = 558.3442
litres
558.3442 x 6 =3350.0652 (the cubic centremetres of the block)
3350.0652 / 1000 = 3.3500
Deck height
i wont be running one but the formular is the same as the bore x stroke formular just replace the stroke with the deck height measurement
Head Gasket
I HAVE NOT REMEMBERED A MEASURED HEAD GASKET THIS IS A ROUGH GUESS
similar 2 the bore x stroke just replace the stroke with the squashed thickness of head gasket and measure the bore of the gasket, or could always CC it with a burette
i.e
87 x 87 / 4 =1892.25
1892.25 x 3.142 x 0.9=5350.9045
5350.9045 / 1000 =5.3509
Head CC
mines 62cc's atm
Piston dish/dome
if i get the kit id run a 12cc dome
add deck height, head gasket, head cc's, piston dish cc's (minues if dome)
0 + 5.3509 + 62 - 12= 55.3509
add the bore x stroke with the above
55.3509 + 558.3442 = 613.6951
devide answer with the above
613.6951 / 55.3509 = 11.08
11.08:1 is the compression ratio id be running
congratulations rob!
and u have this car for sale!? why sell such a beast
I want to get into something lighter, its about 200kg over weight for the Pro Import class I run in but I don't want to strip it out to be a full race car, as it is, it still has glass windows (except doors), steel hatch etc, just needs headlights and wipers back in and its road legal again for someone else.
Rob
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
