  • Replies 410
Posted Images
Ive always used semi's on the dry skid pans for timed events, works well and have placed pretty well in scoring in them.
The trick is, smoother is better, hand brake turns would be the only time they get worn (besides the start on take off, and any lock up) If you time the hand break turn right, you'll have minimal wear anyway :(
So in other words....Don't be a girl :P :P :(
DM - haha nice one!! Your just lucky my 33 isnt going to be there for your competition :(
So in other words....Don't be a girl :P :P :)
LOL, Ok then - I'll use my semi's, you use yours and we'll see who ends up being quicker than who :(
Quick question... Is anyone going on the dry skidpan with semi slicks on?
I know that there are a lot of handbrake turns needed but the problem will be that I have a nice new set of semi slicks that I have just finished bedding in and I dont really want to shred them in one day. :D
My semis are already bolted on and I will be driving to Canberra on them. Can’t be bothered tracking two sets of tyres. If I smoke them on then skid pan so be it. I know smooth is faster but smoke and sideways is more fun. I will drive properly on the track (I promise). Mine are only Azenis so they are not real semis anyway.
Go dirty sartywan's!!!!
i'll be there in tha sillo, with slidie tyrez on ze rearz
GOING FOR SLOWEST YET MOST ENTERTAINING ON SKID PAN!!!
*still be quicker then Bullet32*
proper semis will be rubbish without a warm up.
if you have something like a 595rs or rt215/615 thats been scrubbed in it's the tyre to have in this sort of event. Something that has highish grip but doesn't need a lot of heat to get going. I've found my RS's to be pretty damn good on a skid pan
I would have loved to have been involved in this but i have work tomorrow and the car's still off the road. Hopefully next time. I so want to drive that back bit of track :D.
Im not racing at all :(
remember last years one?
I did 1.40 and came 5th :)
well last time i came 14th with a 31 with stock motor and suspension and locked diff.
only the diff is the same, so bring it on!! hahaha
you might be the slowest, but i you've got some competition for most entertaining. mmmm sidepipe FTW!!!
DM
DM
After I set a good skid pan time, I'll be giving it a good old go for entertainment too. ACT FTW!!!!!!!!!!!!!!!!!!!!!!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
