Okay,
There isn't really an exhaust reference thread like there is for other parts for our cars, so lets post what we have that fits, and where from, and i will up date this post, then maybe it could be added to the FAQ thread?
So everyone who has fitted justjap/x-force/flyn dump/fronts etc, post here
If you have used an exhaust from another car, add it here, and try and show what mods were done. I picked up an r32 exhaust, so will be posting what needs to be changed once it has been fitted, so that others can take advantage of the cheapness of second hand r32 exhausts.
-Ryan
If someone can edit this image of an R32 exhaust showing what they did, it will help me, if not, i will update once mine is done. post-8497-1207469502_thumb.jpg
Brand new cat backs can be found here, starting at 799 for a stainless HKS: http://justjap.com/store/home.php?cat=252
Edited by Ryan1600
https://www.sau.com.au/forums/topic/213676-exhaust-reference-thread/
  • Replies 53
Justjap split does not fit, hits floor, quality not as good
Bos importing and CES split do fit, but cost more, good quality
X force bell mouth fits, good quality
bell mouth produced more kw approx 7-8kw on a hks GTRS on a neo stagea, over a split dump.
http://www.skylinesaustralia.com/forums/in...t&p=3518121
A couple of weeks ago I finally got around to fitting the exhaust to the Stagea. It is a Nismo 3.25” off the R32GTST with a large off set muffler in the middle and a straight though muffler at the rear. I used it because it was spare (the R32GTST has an Apexi 90mm titanium exhaust on it now) and because it was quiet, but at the same time not too restrictive. The old RB20DET made 225 rwkw with it on, so the 200 rwkw target from the Stagea seems reasonable. Plus I am going to use the Performance Metalcraft split dump off the R32GTST, so it is basically the whole exhaust, except the Stagea will run a cat. I already have a new Catco high flow cat ready to go on to replace that crappy compliance one.
On the Stagea, the Nismo exhaust works exactly as I hoped it would, very quiet up to 4,500 rpm, with absolutely zero drone. It has the RB signature howl at 5,000 rpm upwards though.
To get it to fit the Stagea we had to do a few mods. I will post up some pictures, in the interim;
1. We (mostly Liverpool Exhausts) had to add around 4” just before the rear subframe
2. Plus around 3” between the rear muffler and the tail pipe.
3. Cut off the R32 hangers at the sub frame and the rear muffler and weld on a couple of new ones in the Stagea positions.
4. Cost was $190 for the mods, fitting, new bolts, nuts and gaskets.
So it was a pretty cheap upgrade and it certainly makes a difference to the power and useable rpm range. Thinking about it, the Stagea is the first Sklyline/Stagea I have had with a standard exhaust, all the others have had modified exhausts when I got them. So this is the first time I get to experience what a difference an exhaust makes, so I am enjoying doing it in stages, to feel the difference each upgrade makes.
:D cheers :)
PS; for Alex, thanks for buying that FMIC, I found a Blitz 600 x 300 x 100 instead :D .
http://www.skylinesaustralia.com/forums/in...t&p=2740188
I have a Just Jap front dump pipe on my S1 that fits great with no mods - not sure who said they dont fit but mine did.
THe rest of mine is a Tannabe system from a s2 that needed some adjustment to exit at the correct point at the rear. The S1 has an indent for the muffler exit and the s2 doesnt from memory. Just a slight bend to get it to fit spot on.
System is very quiet - only just noticeable at idle and cruising without being too offensive at revs. Revs a lot easier and smoother but not certain of exact power gains.
M35 Exhaust. Had it locally made from a mob that I have been using for years....great quality and great job.....Nice burble for a V6 turbo as well!
Got 3" cat back....will be doing the dump pipe and new high flow cat as soon as the turbo get's done....pretty weird thing happened when I did it as well....boost went up from approx 8PSI to approx 15PSI as soon as it was done....new it would be a slight difference but not that much.
i have an 8th mnth 98 model series2. brought an r34 AM Performance split down down pipe that fitted but didnt meet up to original cat as my car seemes to be a change over model between S2 and S1 models. turns out early S2's have an r33 down pipe length but i live in Adelaide and the guy that builds them is around the corner so had him make a decat pipe. The drive to his place with just the dump pipe was exciting though. 3 inch S/S Trust Power Extreeme 2 cat back ($760 from car toys)was fitted in less than half an hour without even jacking the car up of the ground. i havent heard another stagea other than mine but i know mine sounds sweet as and sounds like it is flowing very freely.
Edited by dmonic1
i went custom, 3" mild, mild mid, magnaflow 8x5 rear
I've just installed a JJ 3" dump and an X Force Hi Flo Cat with existing 3" Cat back to a muffler???? ann a Fujisturbo Cannon
Its quiet as, but it lets the 25 breathe. It may not be the best, but it suits me at this point in time.
Atm l've got a 3" system from turbo back. From cat back its and Apexi Megaboom exhaust.
Question:
If l change the muffler on it from the straight through 3" Apexi "megaboom" ... to a 2.25/4" (inlet/outlet) Magnaflow, can l expect much of a decrease in sound & performance?
Atm l'm getting 97db, but l want to get it under 90 for legal purposes as l don't wanna be swapping and changing exhausts again, but l don't want to loose much/if any when it comes to GO.
Something like this (should look ok with a DAYZ bodykit) and is a little more subtle than the massive apexi thing atm.
http://www.magnaflow.com/02product/shopexd...ain&id=7059
I just went from a 2.5" ghetto spec catback system with one resonator and no muffler to a 3" catback with no resonator and Autotechnica Cannon....
It's loud....make that very loud.
Is that headache LOUD? lol
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
