QUOTE: Dogknight
"You still owe me favours from last time :D *hint hint, nudge, wink*"
You want a lift?!
LOL!
Also it be more fun with more cars but yeah I give you a ride!
Edited by (00)SKYLINE(00)
  • Replies 207
Im gonna do my best to get down there.
Sounds like a big one boys!
Although I too am an immense Family Guy fan, I have seasons 1-6, plus Blue Harvest... Just need season 7.
How concerned should we all be about Noble park?
No doubt a large group of Skylines creates some attention...
Thoughts????
Suggestions for a nearby location guys? One that will fit a lot of cars and wont draw alot of attention.
Its a little while away, but the shell srvo on corner of napolean and wellington rd's is fairly big and there is a nandos there :wave:
Thoughts????
hey mate
this is a meet, an not a cruise so, we will be keeping attention to minimum. aslong as people dont attract more attention (eg: speeding, reving engines) then needed we should be fine
wanye (RCHOO) events Co-ordinator and myself (events sub - committee) will be running the night
lol thats ages away but I wouldn't mind cruising up that way!
Can head through the back way from Endeavour Hills - also no cop attention up that way either so maybe a location to consider
All up to AP on this. Im justn throwing up a suiggestion ass this isbecoming a lot bigger than expected and may cause some issues fitting everyone in.
hmm can't we just press a button and make our car smaller or something? kinda like the "Jetson"
