  • Replies 108
Not my point dude lol Neither is the HKS supra running a 4.8ltr V8 TT... or the HKS 180sx running a RB26DET... they are built for speed... OBHAVE was built to be the fastest 'GTSt' which to me is a RB25DET powered skyline... i'm not saying your wrong but i am jus saying his is hte fastest street gtst with an RB25 in it.
I checked out a R33 Skyline with the trust td06-20g turbo on it, it had 550cc injec reprogrammed ecu, nismo fuel pump, external gate, trust manifold + cooler and apexi exhaust, was making under 240rwkw... my current car has a gt3540 and is making 300rwkw using a rb25... hopefully will get dyno'd soon and hoping to making around the 350rwkw mark maybe more. The trust turbo started spooling up at 3000rpm was on full boost by 4500 or just abit after. my current turbo spools up earlier and is way more responsive aswell. Instead of spending the money on a trust td06 id rather go for a garret turbo and save $$$. My cars on 1.2 bar the r33 with tdo6 was on 1.3 but running standard internals.
No offence, but you bought the Skyline you are driving around already with the Garrett turbo on it. You had no imput whatsoever into the design of the motor or turbo setup, nor did you have any financial or availability concerns determining what turbo the car was going to run.
There's more than just a flat out money decision when purchasing a turbo.
Edit: How can you compare a dyno'd car with an unproven value? You can't make a valid comparison on the vehicles power...
No offence taken buddy. The reason i bought a car with all the set up on it is because i couldnt afford to build a skyline to the specs my car is at now. Now the price between the car i bought and looked at was only 2k. Not only that the car i bought is in much better condition.
I understand what your saying here "You had no imput whatsoever into the design of the motor or turbo setup, nor did you have any financial or availability concerns determining what turbo the car was going to run" but i did have enough money to choose what car i was going to buy and what i was looking for. Both cars were dyno'd and had dyno sheets and spec sheets. Looking at both of them the car i bought was much better and worth its price then the skyline with the tdo6.
"There's more than just a flat out money decision when purchasing a turbo" thats right. It depends on many things.
But what i stated was my opinion and what i experienced. Im not critisizing the td06 turbo... its each to there own.
Originally posted by Roy
RNS11Z... can you tell me what exhaust housing the TD06-20g was running on that R33? An did i read right... about 230rwkws at 1.3bar
Im not too sure about that. Im not so cluey on turbo a/r sizes. All i know is that it was using the TD06-20G turbo.
And it was either making 224rwk or 234rwkw... Im definately sure it was not over 240rwkw with standard internals and re-programmed ecu
True that, though how much is it for a Trust TD06-20g turbo?
/cough $3500!!!
Ok that was a shameless plug, but there is not much price difference between a brand new td06-20g kit and a T88 kit. Maybe you should be comparing your setup to a motor with a T88 and internals as well?
Edit - Like Leewah's? :D
YBSLO4
You are DEAD WRONG about the Wolf3D V4.##!
Hear are some facts on the new ECU:
-Fuel and Ignition maps are tunable every 125rpm and have 16 load bands.
-Fuel increments are 0.004mS
-Ignition increments are 0.035 Degrees
-Idle speed control-adj. every 2 degrees of engine temp.
-Boost control-adj. every 125rpm
Heaps more features are also included in the package. I would like to see the tunning features of the Power fc, just as a comparison.
I have had the WOLF in my car for about a year, and has been running sweet (once it was re-tunned properly).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
