  • Replies 75
  • 5 months later...
when on track and wot I get a rather high pitched pschht.. I have the stock bov and my fmic isnt huge but it is free flowing. meh. is pretty much non existent to anyone not in the cabin any other time, basically very quiet on light throttle ie street driving.
forgot to mention that my return piping is red rubber.. red is better!
Edited by gts-4 dreamer
  • 3 years later...
In regards to what JiVE said:
"And if your after the 'flutter' sound this can also be acheived through the stock bov. Just get a POD and pull the vacum hose out of the BOV. Make sure you block it off real good however, or you will stall."
Have any of you guys actually done that? And what is it about that that would flutter? I've heard of the fluttering before, but i don't know what causes it.
And what sort of effect would this have on driving and safety of my engine and parts?
Sorry to bring up an old thread, but was this ever clarified?
No no no
This will do the complete opposite to whats good
Will open and leak boost when you up it. It will flutter on boost levels where the spring tension is not overcome yes, but you will loose lots of power when it has enough boost to over come the spring
Think about the purpose of the vac line. Provides vac on closed throttle conditions and pressure when boosting to keep the valve closed.
  • 1 year later...
Quick question;
I recently upgraded my inlet pipe(stock rubber) to an aluminum pbm inlet pipe .( for better breathing) . Doing so I had to delete a metal pipe that recirculates air from my bov back to my intake /inlet pipe. Bov is now releasing to atmosphere causing my rpms to crumble and engine almost wants to die off when I rev it. But idle is smooth on its own unless I rev it .i can drive it but when I come to a stop it wants to die off but it will fight on its own to stay on ,it just ruff idles for a bit and goes to steady idle after a sec or two.. By the way my stock bov is pretty loud for being oem as for this topic...
to my understanding this engine was built to reserculate the bov air back to the engine ... . My question is...is there a way to trick my engine/ ecu to running normal as if the bov air was normally recirculating back to my engine or do I have to get a tune to adjust the new setting ?
Edited by ChEwDog
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
