Hey Guys,
I have had some issues with my car as even any mild boost upgrade causes my car to hit its boost cut.
So I am going to install a HKS FCD to my 97 series 1 stagea. But i cant seem to find anywhere which model I need to use...
Can anyone help me with this?
I would also love it if anyone had the ECU pinout too!
Thanks for any help or info guys,
Ben.
https://www.sau.com.au/forums/topic/215576-hks-fuel-cut-defender/
HKS and NENGUN lists 3 types:
STD type pressure sensor supervision types
Type H hot wire type air flow meters
Type K3 Karmann type air flow meters
http://www.nengun.com/hks/fuel-cut-defencer
Stageas and Skylines, hot wire airflow meter, Type H.
Are these FCD's variable resistors to reduce the voltage of the AFM at high revs ? if so, sounds a little dangerous without dynotuning.
Sounds like there is a bigger problem if it is hitting boost cut so soon, possibly consider an APEXI AFC /dynotune to get your mixtures (and AFM voltages) right. My AFC reduces the AFM signal by around 12% at high revs which keeps me well clear of 'boost cut' as well as the extra hp through better air/fuel mixture.
Security tip: those with AFC Neo's, leaving your car unattended for a while, change your 'Air flow meter type' to 'Karmann' from 'hot wire', won't start or run.
Great! thanks for that Chook. and yes it will be tuned on a dyno, I also hav an SAFC II that i will be installing. I was unsure whether that would be sufficient by its self. With my R32 i would still have boost cut issues with the SAFC II installed....
yeah and you might still have with the stagea ecu it allows less margin than the r33 ones does. but for now just try the safc it is smarter than an FCD. If you still have trouble you will need to go full computer
Are the RB25 AFM's adjustable like on the RB30 (Aussie spec') ones? I think they have a series adjustable resistor or something.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
