Okay so the more i read in the Modification Forum the more confused i am...
so im just gonna ask the masters to give me a hand...
okay ive got a stock R33 Series 2, auto, with the only mod being a HKS air pod...
what mod should i do first to improve the performance, but still legal and dont have to top up my tank every second day?
also what is a good exhaust thats good and not HEAPS loud?
and secondly, what is SMIC or FMIC?
Thanks so much!
https://www.sau.com.au/forums/topic/215883-car-modification/
  • Replies 50
The biggest improvements you can make for little money are:
Turbo back exhaust
Front mount intercooler (FMIC)
Fuel pump
Decent set of tires and a wheel alignment
These are the first basig mods you can do.
SMIC = Side mount intercooler
FMIC = front mount intercooler
SMIC = side mount intercooler
First mod would be to ground the black wire to the boost solenoid located on your strut tower
For an exhaust? Give Justin at Everlast a call to see what he has lying around.
I got my hi flo 3" system fitted for $650 all up and that was a BIG improvement.
:thumbsup:
ok
FEW THINGS
go see Mike at MV Automatics in Blackwood, get the auto box serviced and a shift kit installed.
much better shifts for the auto
go find a decent FMIC and install it yourself, so far there goes a grand for the above 2 mods
get a decent cat back system, a hiflow cat converter, and a 3" dump pipe from turbo to cat converter, there's another grand
put in a $50 boost bleed valve, get a Apexi SAFC, take it to a dyno tuner, get it installed, the car serviced with 0.8mm sparkies, boost raised to 10psi, and dyno tuned. theres another grand
so far 3g and youve got a quick shifting auto box, plenty of cool air feed, good free flowing exhaust, freshly serviced engine, slightly tuned with the safc and say around 175rwkw.
yeah mate do the basics first....it will cost you a bit but gives a good ground to work from in the near future.....get a full exhaust system......high flow dump pipe or aftermarket dump pipe with a highflow cat and 3" system all the way through....what you put on at the end is your choice......then get a front mount intercooler for $650-700 from autobarn a good Greddy kit.....they are good value for money...and there you go for about 2K you have a nice sounding and free flowing exhaust and a nice cooling system as well.......
If you wanna go harder then get a full service as tangles said.....bosch 040 or a nismo GTR fuel pump and an electronic boost controller.....with those mods and a service you could easily run 10-12 psi through it and get some decent power mate.....
goodluck with it all
Much better shifts FOR the auto, not FROM the auto ... so its better for the trans then? Not so much a better response FROM the trans?
I've got an auto and wouldn't mind looking after the auto box, but still wanna wind out about 180-200kw
Thanks guys!!!
um out of curiosity, one of my mates tell me to do a manual conversion.
Is that a good idea?
Mechanically, would that break the car in any way?
um, no, not break, just completely changes from auto to manual....
not sure on a 33 price, but when i looked into it for my s13 it was gonna be cheap at 1400ish, so id say around 2000-2500 for 33.
Edited by Damo_R34
You could also get a transcooler....... I will be getting a shift kit and cooler once i put my FMIC on!!
i wont be doing a manual conversion if i were you....but then again depends on what you like to drive auto or manual.....auto's are just as fun and just as good to drive as a manual.....and trust me they are good for city driving....i have a HD clutch and going through peak hour or a busy sat nite.....my god my left calf is bigger then my right
yeah it depends on the application.
if you want to drift like everyone thinks skylines/imports are for then manual.
but for comfort, and if you want to take it on the strip etc, worked auto is alot better.
one of my mates has got a blown v8 ute, every second person asks why its auto, but with slicks and a full custom auto box from mv that thing launches like you wouldnt believe, puts all the manual lovers in their place.
Edited by ted180
Brendan i think you were being a bit conservative with 175rwkw with the mods you listed i would thing a mid 190rwkw
on my standard turbo standard ecu with FCD i made 185awkw @ 14psi i would think 10psi on rwd would be similar
1. Buy the cheapest intercooler core off ebay - 600x300x76 with 3" in/outlets.
2. Get a custom made exhaust and intercooler piping at the same place.
3. Buy a boost controller (preferably electronic) - boost it UP TO 12psi (would go more on stock turbo if u want it to be reliable)
4. Tune
5. Enjoy it for week...maybe 2 before u want more power.
Whilst others here have listed very good advice I think they missed the most important stuff.
To go fast in a Skyline you need stickers. Preferably Mines or Nismo but HKS & GReddy will do.
Next get some neons under the front bar, side skirts and rear bar and you will see your car pull out 2 lengths over a non-neoned WRX regardless of what engine mods it has.
Finally you need an amp and bass. Doof = db = killa whats... as in "What the f__k was that eh?"
After you have these things you need some 19" chrome rims with spinners.
***Disclaimer: It is late and I'm bored waiting to see if my off peak download time has been uncapped. You have plenty of good advice in the posts above***
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
