Hey guys,
Basically i have taken the task of removing turbo's from my R34 GTR by myself, currently i've removed pretty much everything apart from oil / water lines, heat shielding and a few other bits and pieces. Im starting to get a bit confused as to the order things need to come off, and how i go about it. Basically im wanting to know if anyone in the area (Brisbane) would mind lending a hand / knowledge on the process and could possibly help me out one day / evening. I would pay handsomely in alcoholic beverages and food! or happy to give a bit of cash depending on how much work is done! If anyone is available let me know, would be greatly appreciated! Here is a pic of the current state.
Also, have taken stacks of pics of whats happened along the way, hoping to develop some kind of D.I.Y RB26DETT Turbo removal guide at some stage ;)
Any advice / help appreciated! Even if someone could just give me advice on the order to remove the components
Edited by Got Boost?
https://www.sau.com.au/forums/topic/216074-help-request-turbo-removal-rb26dett/
From memory:
- Undo your power steering reservoir and move it out of the way, just gives a bit more room to move.
- Remove the hard lines above the heat shields (have something ready to catch the water).
- Remove your front pipe if you haven't already.
- Heat shields off.
- Oil/water lines off.
- Intake off the front of the turbos off (extra long extension bar highly useful for the rear turbo).
- Undo the nuts between the turbo flange and manifold but don't completely remove them.
- Undo the top 6 manifold bolts.
- Drop the turbos down as far as you can without undoing the bolts and with a long extension put it in between the turbo flange and manifold to undo the bottom 6 manifold bolts.
- Completely remove turbo flange/manifold bolts now and lift out manifolds.
- Undo O2 sensors and lift out turbos.
Sounds easy when you say it like that ;)
Like I said, this is from memory only so I may have missed something.
From memory:
- Heat shields off.
Thanks! Ill look over what you said and give it a go! You wouldnt know which water line is the best to drain from? I've already dumped the oil out so thats not a problem. Havnt removed the front pipes so i should do that i suppose.
I think I used the big centre bolt but I don't think it really matters.
done this job engine in more times than i care to remember....it gets easier the more you do it...just remember, when it gets to you walk away and come back after a beer/coffee/smoke etc. you will get there and feel great when its finally done.
  • Like 1
thats the way.. just make sure you start with at least a new carton of your prefered drink and new pack of smokes(if you smoke while working make that 2 packets)
  • 1 month later...
On this note, what is the easiest way of reinstalling turbos?
Considering how much of a bitch it was to remove the rear manifold underside nuts, it must be easier to lift the rear turbo into position from underneath. Trialled the new one all rigged up through the hole and it 'should' be a possibility.
Any other helpful hints would be appreciated.
From memory.... it took us two cartons of beer.......
do you guys have any tips for just changing the extension and dump pipes?
How much beer do I need lol?
alot.. tis flamin mongrel of a job.. small hands.. perhaps the small hands of an eager to learn young teenager.. something that can bend into like.. a snakey S shape.. prolly only carton of piss for changing dumps.. front pipes are easy to change but dumps are ghey.
:D
Gotta agree... A bitch of a job... Find someone with small hands
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
