Im going to be one of those guys..
I somehow blew my stock r33 turbo yesterday and was wondering what the best option was going to be for me?
I have an r33 gtst with a HKS boost controller running 10.5psi, BOV, turbo timer, HKS Pod filter and 3.5 inch cat back exhaust.
Should i be looking for a 2nd hand stock turbo or something thats going to pump out some more horses. I was going to upgrade later ne way but what else would i need to upgrade if i were too upgrade to another turbo?
suggestions?
https://www.sau.com.au/forums/topic/217484-blown-r33-stock-turbo/
My vote is going with something that is not ceramic shaft/turbine wheel. Basically I would stay away from another stock turbo. I would go for GT30r or even just a 28 if you are trying to keep it relatively cheap. Not too much modification would be required for either of those if ya stayed with an internal gate.
GCG hiflow
HKS GT-RS
HKS 2835ProS
HKS 3037ProS
all of these come as bolt on or in kit form (straight bolt on).
or some hybrid garrett/nissan turbine housing ie 3071 in nissan turbine housing (bolt on afaik)
vanilla garrett T3 based GT2871 3071 or 3076 but more modifications to fit (dump oil and water lines)
what else do you need? spend saturday doing some searches on the above and the answers are all there.
Well if your looking for costs you'll be up for a bit if you want a power upgrade.
you have to consider:
Dump pipe/Front pipe and highflow cat - $400ish $500ish depending where you go for it.
Front mount intercoler kit - $400-$1000 depending on brand
Z32 Air Flow Meter - $250
Engine Management - $1000-$2000 depending on the ECU you buy
Nismo/Tomei Fuel Pump - $350-$400 roughly
Clutch - $500 roughly
Injectors - $600-$700 for brand newys roughly
Decent BB Turbo - $1200-$2500 depending on turbo whether you buy just the turbo or a kit.
Tune - $600 odd
Edited by KeyMaker
Tune - $600 odd
How much power would we be looking at? I assume this is for RB25?
GCG hiflow
HKS GT-RS
HKS 2835ProS
HKS 3037ProS
Can vouch for the GCG highflow
the main questions are, how much power do you want and how much do you want to pay, going a full aftermarket turbo will be expensive once you have done everything else, if you were pretty much happy with the power your making with the standard turbo then just got a high flow, it will be a straight bolt on.
im running a high flow with a vg30 rear and whilst its not the best set up im running .9bar with standard injectors, ecu and afm.
safc fitted tuned $600
highflow the r33 turbo, 360degree journal (bush) bearing with max oversize inlet/outlet, steel wheels, $1300
dont need injectors etc, but yeah youd want 2k minimum for some sort of turbo highflow (GCG are $1950 alone, and you'll want/need some sort of ecu tuning like a safc piggyback)
with a highflow, adj.fpr, z32afm, fmic, 040 bosch pump, 3" exhaust, 2x piggybacks (safc/sitc) I get 190rwkw from a basic tune at 12psi.
250rwkw on average. Depends on the turbo you buy.
id love to find a clutch for $500. i cant find lower then 2 grand!
http://www.skylinesaustralia.com/forums/Ge...ts-t114619.html
Depends how much power you want it to handle of course though.
Edited by KeyMaker
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
