  • Replies 183
Posted Images
Marty..
Battle 3 .. its Black STi vs Blue WRX (Not Black WRX) :)
Daz is kicking Brentons ass there not mine :laugh:
I am pretty sure i get my ass kicked by a girl in that round :banana:
Pete
Pete sorry about that was late I was drunk....
fixed now tho
Leewah...Deal with it :banana:
in the battle 2 vids of prpl 33 GTR vs 300zx, someone behind the camera goes "i never knew a slow car could do that"... haha thanks :D also i never realised that my na zed is loud enough to drown out a gtr from the other side of the skidpan hehe. nice vids btw Martin :P
i'll definately come up to watch/help out at deca masters... will be an awesome event and it's always good to watch the faster cars. hopefully uni exams are over before november 15th deca so i can have another go.
yeah paul said the same thing, it's nothing serious though which is why i kept driving. it's because the zed has pcv pickups on the passenger side cam cover so on hard right hand turns it picks up too much oil and it gets sucked into the plenum and smokes like a chimney... same thing happened at deca last feb but it was worse because the long wang was clockwise last time. not the best look when your driving around blowing smoke but my engine is actually very healthy compression-wise and doesn't burn a drop around town. i'm gonna change the pickups so that they're on the middle 2 cam covers when i get some time off uni and that will stop it from smoking next time :P
Your car was also blowing some pretty severe smoke in the arvo battles, in case ya dont already know... everytime you were on the opposite start block to me so i couldnt tell ya as you were driving off :D
Hanging around DECA threads a bit late at night aren't you Daz?
Wouldn't be waiting for the results by any chance would you?
Might just let you wait a little longer....... They are finished, but I need to confirm one result with Snowy in the morning and then I will post them up.
Yep I beat you all morning :P
Haha! :P
I saw a cone hit & a tonne of tyre smoke when he missed a chicaine!
That's a WD as the timing won't be accurate! :(
I'm going to fight for this one! :P
The one technical issue with your fight Daz is that the lock-up/missed chicane was on the 80% non-timed practise run :P
The good news is I did have 2 other stuff ups during the day so I'm no threat to winning the day anyways.
OK here are the results....
Click Here
Well done to all.
Stand outs for me are:
Daz - Good times all day without one mistake.
Ryan - Let someone else win RWD.
Chris Stacey - Great results for a first time.
Russell - Some great times
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
