Ok guys,
I recently purchased a HID kit off of Slide.
Its a 10,000K 55w kit and im very impressed. Throws a nice light and it isnt too blue.
Heres the pics and a bit of a run through of my install :D
heres where I mounted the passenger side unit. I used one of the many threaded holes that were already present (probably from the airbox)
and simply used a tek screw for the other hole. Remove the airbox if you have one.
You can see in this photo, that the rubber grommet assembly that came in my set had the wires for powering the unit running through it. I decided I would cut these off because it would have been a little messy to fit the new grommet and the old into the one fitting (if you dont understand hang in there, the next few pics may help).
Heres what your car has (sorry about the blur)
Heres the cap for your headlight. The small hole is where the original lamp power cables run. I drilled mine out with a 25mm holesaw so the new rubber seal would sit nicely.
Heres what it looked like after drilling. The hole is offset a little to make sure it drilled over the older smaller hole.
I stripped back the power cable that I had cut loose from the rubber grommet on the light assembly and added some lugs. This was done to the original lamp power cables also. On the original cables, my green wire was positive (the one that originally connected directly on the back of the lamp). Take care with your polaritys. I managed to accidently put the power plug in the unit upside down originally. I Didnt hurt it, but there was alot of confusion when it would work.
This is what my wiring looked like (note, you can see the power cables I had cut running through the new grommet. It is cut flush on the inside and out, I left the cores there as a sort of plug :down:.
A little pre- tidy up photo of the wiring.
Heres a photo of where I mounted the electronic starter on the drivers side. Washer bottle is removed for ease of install.
Heres some photos I have of the lights turned on. This is the original bulb I had (clear blue phillips type)
10,000K light. Note the colour of the parkers, which are the same coulour as my original halogen lights.
Thats it guys. So far im very impressed. The light is great and the original reflectors throw the light out pretty nicely.
Sorry about the blur. The pics were a last minute idea taken with my phone.
Any questions feel free to ask :P
https://www.sau.com.au/forums/topic/217819-hid-light-installation-r33/
They are very white for 10,000k.
Its hard to compare different kelvin ratings as some 8000k kits are very blue and some 10,000k kits look the same as some 6,000k kits out there.
A quick search on google you will be able to compare different branded kits and you will see there is a big difference in the colour, of the same kelvin rating.
I think ill get the 6,000k off Slide. Nice tutorial BTW but i dont think cutting the wires was needed.I have installed a few kits with no cutting what so ever.
hmm. It will be interesting to see how you do it without cutting the wires. I had quite a think about it and though that taking the chop was the neatest option.
Thanks for the feedback.
im about to install a set of these but in the instructions for the ones i got it mentions running a wire from the battery in the boot (+) to the "generator" located in the fuse box, and the use of a polarity ajustor provided with the kit, ne ideas??? i have no clue, i hope all i have to do is that^^
Shouldnt have to.
Should be able run run the positive off the ballast to the globe then the negative off the headlight assemble to the ballast.
Easy! All this stuff about running more wires and cutting and so forth should not be needed.Unless you have a cheaper quality HID kit?
it should also be noted since this is a tutorial that this modification is illegal and cannot be engineerd legal. also R33 projectors will work very poorly with HIDs as evidenced in your 2 last pics. poor cut off, big hot spots and some nice glare. they will be very annoying to all other road users and provide you with quite poor light.
Sorry to nit pick but its reflectors :P
well i put my set on y'day and u were rite,no wiring needed at all, didnt even have to change a fuse, totally plug and play and the globes i have are 6500k and are nuts,so white and bright, not poor light at all and i dont think its too blinding at all. i got my kit for $150! and am told there 100% legal?????!!
  • 1 month later...
yeah i put in a set of 8000k HID xenons few months ago and let me tell you ive never even used my high beams since, these things are that bright its not funny, its like double high beam power but pure white light.. best upgrade ive ever done.
note
i never put a sliding kit in and mine are only 35w and from ling long land off ebay so yeh
ill get some pics up when i find mine
Edited by l0WRB
I love my hids.. Got BELLOFs (jap brand) - very expensive and totally love it.. have had in my car for 2 months now i think and never had a problem.. no ones flashed me yet etc etc.. driven past cops, people, cars, dogs, cats etc.. lol.. even had a cop on the other side of the intersection.. Got a friend to drive in front me and he said its fine.. no glare etc.. So im happy!!
^ heheh yup havnt used my hi-beams since!!
Actually mine is much brighter than the hi-beams..
Edited by siddr20
Hmm. Those pics are pre-adjustment and the lights are shinning on the hill. After I adjusted them up a little, theres no doubt in my mind they give off better light. Haven't used my high beam since installing them and as yet have not been flashed by anyone. Even though I think they would be slightly brighter to oncoming traffic, I dont believe they are too bright at where I have them.
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
