  • Replies 92
back together again!!
only a few loose ends to tidy up and she's ready for dyno tuning Friday afternoon to handle the bigger injectors :P Justin at Competition Tuning and Performance will be doing the tuning.
also thanks to Mobile Auto Hoses for helping us out a little with the cost of the turbo lines.
congrats to Beau today who made it through to the top 12 in Driftstate at QR today.
He qualified in 17th position out of 24, then won his first battle after a re-run. Then in his second battle, he drove the car out of sight, but the other car simply had more power and Beau couldnt keep up.
However I was very happy with the way he drove and once we get a chance to put a big power motor in the drift car, I am confident that Beau will do really well in future events.
there was about 8 other cars there over 400hp@rw , I lost to a 415rwhp 2.2 tomei 180sx that is about 970kg , mind you he is bloody good too , just finished 5th two weeks ago at DA Adalide
Had the QLD r2 State championship on sunday , first time driving it with it's new setup turbo , it was a shame I had to take off my tower brace to fit it on as the front seemed to wash out a little coming out of a turn , and I have lost my 2nd gear sycros .
So had practice from 10 , got about 3 laps in and found I was lossing power , opened the hood and found out I had melted a cooler pipe as it was too close to the manifold , so had to rush around to the supercheap to buy and then fit a new one , and also make a section of heat shield to make sure it does not happen again .
Then came qualifiying , I had one more practice lap to check the setup which felt good , so I lined up for my first qualifying lap , started out great but I missed 3rd going into the dipper and went into 5th , but managed to recover and get through without to much trouble. My second qualifying went well besides a little bit of dirt turbo .
Ended up qualifying in 17th and had my first battle up against the TOKAGE soarer driven by Josh Botcher , a well proven driver who normaly drives his FC rx7 , but due to brakege was picked to drive for the TOKAGE company.
First lap I was chasing , and I managed to stick very close but at the cost of losing angle a few times , lead lap I hit the dirt once which was being judged very harshly , so it went to a re- run where as the Soarer spun both times due to a bad tyre , so I was through to top 16.
Next battle was against my very good friend Eugene in the Federal/Mercury 180sx , a seasoned DA competitor in a 400rwhp 2.2 tomei 970kg fully built drift rig. First lap I was chasing and lets just say he pulled away with his foot to the floor , and on my lead lap he followed very well , so I was knocked out , but was told by many people that it was a very close battle considering the power difference. I was told later that with my score against Euge that I made 12th place
  • 3 months later...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
