  • Replies 108
i dont think its being parted out, i saw some old dude with dreads driving it round the other day. BTW i thought there were two pre-facelift (non iron mask) fronts? one has slimmer headlights and different bumpers and a gay honeycomb style grille
wheres everyone find these dr pics. their awesome
just runnin basic stuff mate, im a tight ass apprentice lol.
s13 coils, welded diff, r32 brakes, hydro, r31 swaybar, rb20 (fj was gone when i bought it), cooler, oil cooler, screamer pipe, strutbrace etc
hopefully get some more pics next time i go out. been busy so havent been out 2 a drift prac session in months..
Keep the drift pics coming! What mods are you running outatime to get it sideways like that?? I'm looking to do much the same with 15in wheels.
Some my favorites.
Where did the 4th picture down come from?
I'm more interested in the car behind the grey for Paul Newman connection.
Cheers, D
was a iron mask front for sale up in qld a while back. no idea if sold by now or who the seller was. but was on here somewhere..
will upgrade rear swaybar when i find a cheap 1 goin. had a 31 bar layin round from 1 i use to own. made a huge difference out on the track, took out alot of understeer and just felt more stable when goin over 80ks sideways. also got unknown rear spring rates that feel bit soft so that wouldnt be helpin tho..
Edited by OUTATIME
there was a sweet R30 (and R31) picture thread going for a while over at JNC forums but it seems to have died down now.
This 4-door DR30 provides a constant source of inspiration for my own build
Cheers, D
Found it maybe 4-5 years ago on a japanese website when I owned my first DR. It was in at dr30 meeting. Never noticed there was a paul newman version hiding in the pic.
I had the front end pic but deleted it. This was before I didn't really know what a sharknose was... :banana:
Still to this day one of my fave pics and is one that I take alot of inspiration from.
Edited by D-limo
Looks like it goes well for basic stuff mate!
Keep flying the r30 flag.
Ya seen that One, But I think i Missed It :down:
Front Bumper is easy! Any R30 will fit, but what year vintage have you got? 81/83 have the narrow bars & 84/85 have the wider ones.
Headlights and grille/filler is a different story altogether, but not impossible.
Will have to talk to a couple of guys to see what they say.
Will let you know when I know more, but in the meantime, I need to know what vintage we're working with.
Cheers, D
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
