  • Replies 895
Mine idles dead flat. Try spraying some carbi cleaner around the rubber seals of the injectors, if the revs change then it means you have an air leak.
These things use closed loop control of idle, but use the settings in the open-loop table as a rough starting point for idle control duty cycle, so you set up your idle in open loop and then switch on closed loop and it is done.
Havent taken it to ESP yet, will talk to them tomorrow, taking the car back to Skyline Performance to fix a slow oil leak first. Car also broke down on mild throttle when I took the car for a quick drive yesterday. Was breaking down on anything more than 4-5psi when esp were first tuning it. after the put in new bkr7e's it only did it once on the dyno.
Was advised by someone else putting in better sparkplugs wouldn't hurt?
use PFR7B's on pump
coils maybe.
Use BCPR7ES forget platinum plugs and tell your tuner to stop using BKR's in RB's.... they are 2.5mm shorter and only amplify ignition problems due to poor contact.
this has been my plug of choice for a couple of years now and i couldn't agree more...
have used for 185, 240 and 265 rwkw
I use it now too. Only problem is having to order them in prior to each change.
most repcos have them in stock, i usually buy 30-40 at a time of both BKR7E and 20-30odd BCPR7ES cause my work is split between RB's, SR's and JZ's.
*backs away from narre autobarn being veeeery careful not to take eyes off trent*
haha nah but they always have Z32's, BCPR and BKR plugs 040's, 02 sensors etc out the back ready to go for me so if anyone ever needs them in a hurry on a sunday or whatever it may help you out. Crazy range of silicon hose instock too.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
