  • Replies 895
huge thread, looks good.. anyone know rough pricing for the ecu itself? (since it just plugs into the factory loom, no install costs required yeh?)
for a 34GTT install is required. the map sensor lines have to be run into the engine bay and the intake temp sensor installed.
they were $1650 inc GST when i bought one for our circuit GTR. That was a while ago but price should be around that mark.
yeah $1650 inc IAT and MAP sensor etc.. still that price we sold a few lately.
Ive found them a good thing but the Best? No way, top 4 yes.
best no, quick and easy YES, results also easy.
The new Haltech Platinum rates a mention and is one of the best new computers around now especially as the new software is 10000000000000000000000000 times better than their old system. (the old software was clunky)
hmmm well there was a gold box under the dash from what i saw and if the vipec was as good as it's ment to be i cant see why it hasnt been changed, if you read all the crap that some people have been carrying on it should have been changed if vipec is said to be so much better ? but i think it's just the marketing ploy, thats worked well too this point maybe some truth should be told "sometimes" when it suits
ok, wouldn't suprise me if the motec's still in there as I know how little time Mark has to work on his own car and the motec does an excellent job. I'm sure there will be a vipec in it's place when he gets time in the future though, I'll ask him next week when I place my next order.
Now you do.
The logging software on the Vipec (it has been updated since I had used it the first time) was not that special. Anyway, the Motec SDL which is just a display is not compatible with the Vipec (I think).
Now you do.
I allready did.
sdl can be unlocked for logging too
no conspiracy theory...Mark was simply busy helping out everyone else get their cars ready over the last month. He has generously put others first before even considering his own car.
Nice time today!
It was shame about the dial-out.
We almost got Theo up and going for the Qualify too but ran out of time so he didn't get to run again which is a shame.
What did Mark run again? 7.8 or something, that's pretty decent. When's he swapping out for a slider clutch to knock another second off?
Nice time today!
Theo had a run in the grudge races later in the arvo, had what sounded like missing issues and clicked it off before half track.
Even though i wasnt out there perosnally racing, there was a bit of me in both pauls and theo's cars :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
