hay all just have a few question,firstly its an rb20 and for the build i so far have r33gtr cams,crank shaft and conrods. to fit the crank and rods the engine needs to be machined?for clearances?also can get some rb26 pistons for cheap,or would i be better of getting some forgies although i am on kind of a tight buget?also what kind of displacement would this take the rb20 to +do for it torque wise?
thanks all in advance
https://www.sau.com.au/forums/topic/218619-rb20-engine-build/
more power,yes i am on a tight buget but have a brother that owns an engine reco workshop ie can do all the engine machining block blue printing ect.......for free and have a friend thats a good machanic that is gonna pull down the engine with me and put it all back together.+have alot of the parts for it already.
You can either get Tomei 2.4L pistons which i think are 82 or 83mm or you can try some custom cosworth etc pistons. The head gasket will msot likely be Tomei as well to suit the new bore.
Do a search for RB24, you should be able to get plenty of good infto. Particulary from Legend01 who built a nice 3000rwkws example
thanks for all the input,was just asking about the pistons gtr didn know the difference in size(bore).buget don't really have one just don't want to go stuiped.as i have just purchased a 2way and coilovers and in the process of buying a turbo 2530 maybe 2535 or 40 considering the build,thoughts?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
