  • Replies 47
thanks for all the comments :D
not that many r32 gts-t here in sweden....
the bodykit takes some time to get used to, but hence i'm not a good photograf the pictures doesn't give a true picture of the car, looks MUCH better in reality :(
the next thing that i will buy for the car (exept getting the tires on the rear wheels so the car will have the same wheels as it is in the front) is a LED lightbar, much be able to look more like a policecar and if someone hade missed it at the shows (if possible) they won't after that :)
the night streetraces will be fun when i arrive..... "the police is comming, lets get out of here" MOHAHAHA
Looks fantastic mate, good work! I'm a bit iffy about the rear bar, but hey, if your happy with it thats all that matters. the whole Jap Cop theme is sooo good! Are you doing anything else to the engine, suspension, and brakes?
akeenan the "japanese text" will be replaced with the real japanese text for Tokyo Police, the grapics guy couldn't open the data file i gave him, and as usual was there "plenty" of time before i needed the car :D
the text on the doors will be 東京 (Tokyo) 警察(Police) but with a more bold text that is on the doors right now....
NA_Goodness the suspension is HKS coilovers, and a front strutbar will be there aswell.
the brakes will remain standard to start with, perhaps groove them and put on better callipers (think that is the right word)
the engine will get a light tune.
r33 turbo (with steel impellers not ceramic)
444 gtr injector
wallbro fuelpump
perhaps a remap or another box
aldready have:
FMIC
3" exhaustsystem
3" downpipe
Oilcooler
think that will do something to the performance...
Edited by Daniel Landström
when i get back from work (work in a different town from where i live at the moment) on wensday will the trunk get some attention.
the sound installation will start with sound deathning the entire boot incl. the trunklid.
the installation will be clean with the amps visable and the fuses seen behind some glass (that easily can be removed to be able to change them)
the trunk will either be covered with black vinyl or grey carpet that looks like the standard covers in the trunk.
Very good theme and the headlights turned out mad. I thought the wider guards are supposed to be vented near the doors though? You should have cut the holes for them. I hate when body parts are made to look vented but arent. Bonnets are big offenders of this.
the next thing that will be done on the car is that i tomorrow will start building the audio installation in the trunk, will keep it simple.
and also sound deathen the trunk.
have finally found the LED lightbar that i have been looking for :)
a proper police car must have a lightbar :D
The clear headlights covers can be bought from ebay.
Also with the LED tail lights, he is going with LED lights on the roof so the tail lights will suit the theme.
Edited by NRV155
how hard are they to chuck on(what's involved)? ive never really tried to take the lenses off my headlights so not too sure how hard it is.
It's not too difficult.
Smash your glass lense, use a heat gun to heat the silicone one area at a time and then pull the glass out.
DO NOT heat the whole unit (or attempt to) and take the glass out in one piece. You'll melt the housing.
think i might wait till i smash them by "natural" cause lol
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
