Yeah thats the rims and car. The pumped out guards are a give away its a gtr. I also would love to know what rims and sizes they are. Great lookin car Travis. Have got a pic and dyno result, ill post it up as soon as photobucket comes back up from maintanance.
It put down 175.3kw and seemed to be still climbing until it suddenly dropped off. You should see alot bigger no. when you get that sorted out.
well i think it hit spped limiter when the power dropped off.So if it wasnt so gay it should have made more.Thanks for your comments ay i try to make the car look nice.Rims are axis 19x9.5s.The car is running way to rich as well adam was sayin that that could be a problem so power fc will sort that but yeh gotta sort the money out for that
  • Replies 107
Hi Travis32
if u don't mind, can i try your wheels on my car when we meet next time? just wanna see how they sit/look under my guards
nice looking wheels mate!
We'll have to see man not sure if they'll fit ay
Yeh it was 2nd on the dyno so not happy with the results ay
Yeah I was real surprised. I thought it might've been a worked GTS-t with GTR guards. But I thought 'surely you wouldn't get plates saying RB26 if it didn't have one'. PowerFC will make a difference mate. You'll get heaps more out.
Yeh but keeping in mind the car is fairly stock and i think it hit speed limiter.Thats why think it dropped so sudden like it did.Power fc and turbo etc are on the cards but just gotta get the money together
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
