Hi all, im going to get a r32 gtr says 49km on it, I already saw it and test drove it, it seemed fine, but should I bring it to a mechanic and get a compression test ect? also are they prone to breaking down or quite reliable if you dont drive it like mad? I have acouple mechanic friends but they never worked on a skyline before is it pretty straight forward to do the timing belt and such?
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/
I think you should always get it checked out by a mechanic that knows about them. Don't just get a mate to check it if they don't know about skylines. take it to a performance mechanic.
To my knowledge they are usually pretty reliable if looked after, also depends on what mods are done and how the previous owner looked after it.
That said it is a car and cars break down!!
Good luck with it, hope it treats you well!....
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879414
GTR's are reliable as long as you perform maintenance in accordance with how you drive it...drive it hard=more maintenance and possible breakages. I dont drive mine as a daily driver but some guys do...I think they're too special to waste on the drudgery of work.
Get the car up on a hoist and check the underside, 49K sounds too low. Look for signs of wear and tear.
Good luck
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879564
Like what others have already suggested, don't pay so much attention on the km's as it is pretty much impossible to find a genuine example unless full log book has been provided. Otherwise, you just don't know the history of the car.
You should do a general overall body and chassis check 1st BEFORE even looking into the mechanical side of things as none of the other bits will help if the car has a bent or a "straightened" chassis. A majority of GTR's on the market will have some kinda of repair done to them, such as panel replacement...etc. This is fine, as long as the chassis alright.
For a general body check (BRING A GOOD FLASH LIGHT WITH YOU!!) and check the following:
- Look for uneven panel gaps around the bonnet, bumper, door, side skirts, rear bumper, rear boot lid, lights. Use your hand to feel the gap on both side of the car and see if they are the same.
- Look in the engine bay and see if there are any evidence of fresh/mismatching paint
- Check all the bolts (e.g. bonnet hinge bolt) and see if they've been turned
- Check the bog lines in the engine bay and see if they are consistant on both side of the car
- Check in the wheel arch with your flash light and see if there are any crack or RUST, or any inconsistancies.
- Check all around under the car with your flash light and see if there are any RUST, bent or damaged support rail or any inconsistancies.
- Check all around under the car for any sign of oil leak.
- Check in the boot, remove the carpet and spare wheel and see if there are any major rust (minor surface rust is ok).
- Stick your hand into behind both rear quarter panels (where the car jack are kept) and feel if it is damp or has water collecting in there or rusty.
One of the huge thing to look out for is RUST. Some surface rust is ok since its a 15 year old car, but deep rust with bits flaking off will need treatement urgently and you should stay away from such car. STAY AWAY from cars with a painted bottom (usually black), which maybe an attempt to hide repair marks, or even a 2 car in 1 or 3 car in 1. STAY AWAY from cars if there are clamp marks or unusual gashes on the bottom support rail (straightening machine mark). One thing that I found when I was shopping for my 32GTR is that you HAVE to look at at least a couple different cars and compare. This way, you'll have a better idea of the general condition and whats good and whats not.
I still recommend you getting it independantly inspected by a qualified mechanic if you are unsure.
Edited by __PhaseShiftDown
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879577
Thats sounds way too low! Unless the previous owner drove it once a year... If not, its been winded back to a rediculous amount which is just stupid and no one would believe.
Has it got a 180km/h speedo (stock)? Only thing to judge by the K's being genuine (but still)
Check out the interior
Listen out for sounds, noises.
Check the gauges, take it for a test drive.
Check out the engine bay with your mechanic. (Prefferbley get a mechanic who works on performance cars)
Ask as many questions as you can, which will make you see how genuine the seller is.
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879799
Check for weld spots in the engine bay and get the chassis checked out thoroughly. You really want to make sure that if it has been in an accident that the repairs were done correctly (and lets face it; a much higher proportion of these cars have been in accidents than we actually realise).
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3881111
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
