Now Accepting Orders! Ati Super Dampers (harmonic Balancers) Gtr R32 R33 R34's,
  • Replies 115
Posted Images
Thanks Johno,
recived mine this morning..
Shaun, may be a stupid question, but where does the crank key go? i havn't seen that while removing the stock balancer.
and what brand assembly lube did you buy and where from (i have checked the usual supercheap etc. they never seem to have anything more than grease)
Feedback left also :P
as for Kent, you will notice a keyway on your crank shaft, it goes in there.
it may have fallen out, but this is the locating device for the balancer
Thanks Johno,
Ill post some pics for you to see where the key is. You should put the engine at top dead centre before you begin. When the engine is at TDC, the key will be facing up. Its important to check the key and replace if damaged. For only $2.20 its worth it.
In regards to the PS pump, im using a different model pump, so i had problems with the offset of the pulleys. I therefore, had to modify the PS pump bracket, which meant getting a machine guy to elongate the mounting holes in a mill. This way i could slide the bracket back and forth and get the correct offset. Its been going fine for ages now, so it does work.
The assembly grease is in the third picture. I had trouble finding it too, but eventually came across it at Repco. I was recommended to definately use Moly grease.
Edited by Shaun
Thanks guys,
I checked today and the key is there, i didn't realise from the pic what it was, i didn't expect it to be so small :banana:
will check out repco now i know what it is called!
I had the wrong ATI pulley a while back as well. I have a vspec 32 so the shop sold me a R33 ATI because they though the crank is different to a standard 32.
I had to mill the power steering pulley a few times to get it right. Lost a couple of belts on the road and at the track :banana: There isn't any tensioner pulley on this belt so a small difference in the offset is all it take to throw the belt off. The GTR is heavy without power steering. Sorry we had to mill the pulley a few times so I don't know how much we took off in the end. It's very fiddly to get the offset right :D
Can you order the PS pulley only from ATI? What is the cost?
Edited by 9krpm
I had to mill the power steering pulley a few times to get it right. Lost a couple of belts on the road and at the track :) There isn't any tensioner pulley on this belt so a small difference in the offset is all it take to throw the belt off. The GTR is heavy without power steering. Sorry we had to mill the pulley a few times so I don't know how much we took off in the end. It's very fiddly to get the offset right :D
Yeah, its definately fiddly to get the offset correct. I just threw my first power steering belt yesterday; first problem ive had with that. I put a straight edge on the PS pulley and balancer, and found that it was slightly out, so i fixed it up, went for a long drive and it was ok. Its good being able to slide the whole pump and bracket assembly back and forth to get the offset right. As long as the straight edge contacts all four sides of both pulleys, it should be spot on.
Shaun.
Just wanted to confirm everyone got their balancers... If you didnt please let me know asap.
Cheers
Johno
ah... what exactly do these things do?? and are they only applicable to high kw/hp engines?
any chance of a second group buy, missed this one by a day, almost cried
thanks dan
ahh 33 s2 - With the Aussie $ the way it is.. It wouldn't be anywhere near as cheap as the first GB. If there is enough interest I would do another. If there isn't enough interest I have an Aussie supplier who can supply them pretty cheap & quickly PM me if you want to go that way.
SS8_Gohan - Not nessesarly for big HP applications, the ATI balancer is perfectly balanced and Eliminates torsional crankshaft vibrations.
http://www.atiperformanceproducts.com/prod...s/damnissan.htm
Cheers,
Johno
SS8_Gohan, they balancer is a consumable item though (like a timing belt/fan belt/ idler bearings etc.)... i am pretty sure the nissan recommendation is to replace them around the 100k or 150k mark (can't remember exactly)
All that info is on the ATI site i think. Im pretty sure they recommend every 10 years for street use.
For those of you who have installed their balancers, what belt sizes have you used?
I emailed a few guys around the world before i bought my balancer (600 - 1000 HP) and they all said stock size belts. Now unless im missing something major the only one I can get on is a PK 4 980 on the AC.
  • 8 months later...
anyone got a spare balancer for a r33 gtr. looking for the smaller under 500 HP. or does anyone know where to get one locally
cheers
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
