seller has no idea
it's not 'M Tune' it's M-spec, and that isn't one: an M-spec is basically a V spec 2 with a factory Robson leather interior and suspension more suited to the European market.
No there is no such thing as a Nismo M-tune.. there is however a Nismo M-spec.. maybe he made the bodykit himself and is dubbed the M-tune.. which would explain the 'rare' part.. or maybe its rare cause there are 0 recorded Nismo M-tune GTRs'...
In the car sales add its a only a V-Spec,
V-Spec's had smaller Nissan badges and the the "V-Spec" is a sticker only. Which is what this car is.
IF it was a M-Spec Nur, it will be based apond the V-Spec II Nur models.
Larger Nissan badge and a "V-Spec II Nur" as a badge. Usually its a Millenium Jade Colour with N1 running gear.
The bonnet should have a NACA Duct as with all V-Spec II came with. V-Spec's did not come with a NACA Duct.
M-Spec Nur's came with black leather interiour and a gold stitching trims with softer suspension for a more smoother luxury ride.
Edited by (00)SKYLINE(00)
  • 1 year later...
As I'm currently looking for a GTR, this one is still advertised and it was last updated by the seller on 13 December. So this isn't a 2002 VSpec 2 hey? This would be an older car? Thanks All.
Edited by Godzilla GTR
The 2002 M-Spec R34 GT-R did 'not' come out with the NACA Duct as did other VS-IIs.
The bonnet is aluminium 'not' C/F as with other VS-IIs. Believe it or not...
Leather - Yes
Power heated mirrors - Yes
Heated Front seats - Yes
Softer (fine grip) steering wheel - Yes
Ripple Control shockies for smoother ride - Yes
Softer Stabiliser -Yes
Typical VS-II rear stoppers - Yes
But... hang on...
Notice the pedals? Not typical VS-IIs in shape are they? Left foot rest is not aluminium either.
And as mentioned earlier, all M-Spec GT-Rs should have the larger/thicker NISSAN badge on the boot & this one doesn't.
Now Terry's puzzled...
Check the one on www.powerplayimports.com if you like?
Thanks Terry, this is an unusual one.
Cheers.
Leather - Yes
But... hang on...
^^^ Obtain the VIN# - Tell us what the "VIN Fasted" check reveals won't you?
With that check, also ascertain whether or not it comes from Northern Honshu or Hokkaido (re: possible rust from salted roads)
Sure will do. That M-Spec at Powerplay looks nice. I'll enquire on that one.
Cheers.
That seller has no clue about the real Nismo Tuned engines. There are 4 Nismo engine variants with an R34. They start with the S1, then R1 and the pinnacle is the Z Tuned motors. But in between the R and Z Tunes, Nismo decided to make one called a Fine Spec engine and only 70 of them were made in 2009. All sold out quite quickly.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
