Guys i just need something cleared up. In regards to an r33 gts25t series 2, there was the vicious lsd and active lsd.
I have an r33 series 2 1996 model with vicious lsd and i really wana know whats the difference between the two and which is better.
Im always thinking that i should have gotten a later model r33 with active lsd and cant stop thinking if i should trade in or sell my car to get one.
If you guys could tell me the difference, what they do and which is better it will help me out so much and give me time to think about other problems before i goto bed.
Also let me know if its worth selling my car to get one or just keeping mine. Cheers
https://www.sau.com.au/forums/topic/220445-active-lsd-or-vicious-lsd/
eventually your viscous dif is going to give up the ghost it's just a matter of time, go with a mechanical lsd cusco or along with those lines.....factory lsd's arent that great anyway, i tore my factory lsd to shreds the first day at the track.
you couldn't go much later with the R33 series as the R34 series coming was the talked about thing come 1997.
Edited by nizmonut
Im curious as to how the active LSD actually works?
Is it electronically controlled somehow? Or just like a progressive limited slip effect depending on traction available? Or something else?
Yes they are electronically controlled and use a wet multi plate clutch system. Nissan only made a relatively small number of 33's with the A-LSD, I don't think it was only available on the later model 33's though, it was on option on all the models I thought, including S1. I have driven a fairly powerful R33 with A-LSD. It was a bit weird! But it think for most purposes it would be better than a viscous LSD. Certainly not worth selling your car for though!
yeah its not worth the hassle and change of car for it
the a-lsd or vspec rear diff (same thing) has a vspec pump on the right side underneath the car on a shelf.
the reservoir is in the boot on the right hand side and takes auto transmissions fluid.
the system (the same as the vspec diff) watches the abs wheel speed sensors. when it detects one of the wheels is moving rapdily faster than the other, ie: wheel spin
it turns the vspec pump on, which pumps fluid into the diff housing, to make it lock. i ran a bypass into the pump relay and put a switch in my car so i can run the pump non stop.
it doesnt seem to help much and it still sometimes single-spins so its a bit annoying. when it does work correctly the car glides perfectly, like you would expect.
Is it also goes with the R34 as well? does it also take auto transmissions fluid, because I'm using the nissan factory oil. The oil color is Red. Does it make any difference?
the viscous LSD is pretty average. i'd go as far to say it's rubbish. the active LSD is not much better and really a bit of a wank tbh.
your best bet is repalce your viscous diff with a nice, proper mechanical LSD. 32 GTR LSD is pretty cheap second hand, and you can easily replace the clutch packs to make it good as new. or just buy a cusco,kaaz,whatever centre for your current LSD. then enjoy nice, predictable diff behaviour and no more single spinner.
Ok cool, im still a little pissed with myself for not waiting and getting a 40th anniversary r33 but what can you do.
Well if u guys think its not worth the hassel of selling mine for one then im happy to keep mine, it is a skyline after all.
Dont be dude.
Although it would be cool for only because its rare it doesn't offer any substancial advantage. Plus if you want the car to look good you wouldn't want the 40th anniversary kit anyway.
It is not worth the hastle let alone the stress to think about it.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
