Wanting to Buy or Borrow
RB25DET R33 GTST Heater Hoses', Under plenum, along firewall...anything to do with heater hoses in the engine bay...in any condition - as long as they are the correct length and shape. Would prefer the whole lot from someone if I can.
PM me.
++++R33 GTST defected ++++
Stock front and rear suspension
Stock Exhaust
Stock wheels
if any one has any of these parts they could let me borrow to help me through regency, it would be much appreciated :)
Cheers, nathan
+++ R32 GTR Identity Check +++
Stock fuel pressure regulator
I'm thinking i need a stock fuel pressure regulator (suit RB26) to clear ID check.
Mine looks a bit gay with yellow hose and gauge, may cause undue attention
Standard exhaust.
Have recently fitted Cat which quietened it a bit, but its still a bit loud, contemplating fitting a quieter exhaust for the inspection. ? If not available i might chance it. Any thoughts?
ryan, if you're driving over with us ive got a pair of 32 GTST stockies with the centres bored out to suit ford hubs that i carry as spares, so if u strike trouble i have them :)
keep an eye on pressures, that will be the key. Underinflated tyres will heat up excessively and blow out, generally what happens on trucks anyway :)
Hi guys.
I need to borrow a pair of stock GTR BOVs. I believe they can be from any of the R32-34 but am not 100% positive. I have a R32 GTR.
I need to lend the BOVs to Simon at Morpowa (Modbury North) to make up a custom return pipe for me as St Marys Collision Repair Centre lost mine when they failed to repair my car over the 12 month period they had it in 2008/9.
Please help me out. I have only had my GTR for 2x 3 month stints since blowing the engine over 4 years ago and in that time have poured thousands of $ down the GTR sumphole yet have had very little enjoyment from it. ATM I am in a very tight fiscal position and will be so until either Shannons finally pay me the $3.5k they have owed me since 2009 or I receive my legal settlement that has been going on since 2002.
Cheers.
David aka writeoff
Edited by writeoff
Hey,
I'm after some 5x114.3 rims with legal tread to borrow for a few weeks to just a month tops.
Must be the same sizes and offset all around and no smaller then 16" for the new car.
I will pay for the usage for helping me out of course.
OH, and I wont be driving on them very much as I leave for work for a couple of weeks. I just need something to put the car on.
Edited by Import S13
Kye i have S14 rims you can borrow, 3 of them have awesome tread, the other has around 50% tread and is different but shouldnt matter too much if you are just rolling it around. pickup in wingfield!
Im after somebody who runs a VG30 Turbo on an RB20.
Must run:
VG30 15psi (or their abouts)
FMIC
Any injectors is fine
Any AFM is fine
Should be making around the 19-205rwkw mark
Would like to borrow your ECU for 1 day and will give you $50 in return. Would like to get the tune copied by a professional.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
