Wanting to Buy or Borrow
RB25DET R33 GTST Heater Hoses', Under plenum, along firewall...anything to do with heater hoses in the engine bay...in any condition - as long as they are the correct length and shape. Would prefer the whole lot from someone if I can.
PM me.
++++R33 GTST defected ++++
Stock front and rear suspension
Stock Exhaust
Stock wheels
if any one has any of these parts they could let me borrow to help me through regency, it would be much appreciated :)
Cheers, nathan
+++ R32 GTR Identity Check +++
Stock fuel pressure regulator
I'm thinking i need a stock fuel pressure regulator (suit RB26) to clear ID check.
Mine looks a bit gay with yellow hose and gauge, may cause undue attention
Standard exhaust.
Have recently fitted Cat which quietened it a bit, but its still a bit loud, contemplating fitting a quieter exhaust for the inspection. ? If not available i might chance it. Any thoughts?
ryan, if you're driving over with us ive got a pair of 32 GTST stockies with the centres bored out to suit ford hubs that i carry as spares, so if u strike trouble i have them :)
keep an eye on pressures, that will be the key. Underinflated tyres will heat up excessively and blow out, generally what happens on trucks anyway :)
Hi guys.
I need to borrow a pair of stock GTR BOVs. I believe they can be from any of the R32-34 but am not 100% positive. I have a R32 GTR.
I need to lend the BOVs to Simon at Morpowa (Modbury North) to make up a custom return pipe for me as St Marys Collision Repair Centre lost mine when they failed to repair my car over the 12 month period they had it in 2008/9.
Please help me out. I have only had my GTR for 2x 3 month stints since blowing the engine over 4 years ago and in that time have poured thousands of $ down the GTR sumphole yet have had very little enjoyment from it. ATM I am in a very tight fiscal position and will be so until either Shannons finally pay me the $3.5k they have owed me since 2009 or I receive my legal settlement that has been going on since 2002.
Cheers.
David aka writeoff
Edited by writeoff
Hey,
I'm after some 5x114.3 rims with legal tread to borrow for a few weeks to just a month tops.
Must be the same sizes and offset all around and no smaller then 16" for the new car.
I will pay for the usage for helping me out of course.
OH, and I wont be driving on them very much as I leave for work for a couple of weeks. I just need something to put the car on.
Edited by Import S13
Kye i have S14 rims you can borrow, 3 of them have awesome tread, the other has around 50% tread and is different but shouldnt matter too much if you are just rolling it around. pickup in wingfield!
Im after somebody who runs a VG30 Turbo on an RB20.
Must run:
VG30 15psi (or their abouts)
FMIC
Any injectors is fine
Any AFM is fine
Should be making around the 19-205rwkw mark
Would like to borrow your ECU for 1 day and will give you $50 in return. Would like to get the tune copied by a professional.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
