hey all
just bought my rb30e on the weekend and am almost certain its a series two block however there are a few little things that are warrying me. i have attached some photos so those in the now can hopefully put my mind at ease..
http://i13.photobucket.com/albums/a272/danp_87/side1.jpg
as you can see in this photo it has 2 of the 3 holes you would think it should have
http://i13.photobucket.com/albums/a272/danp_87/front.gif
and in this photo it appears to have the flat area above the water pump for the second tensioner location.
i havent pulled too much of it yet cos if it is the wrong motor it can go back in the quokka next week.
also on a totally unrelted thing. the 26 head has the same stud pattern as the 30 block just a thicker stud yeh??
thanks for all the help
dan
https://www.sau.com.au/forums/topic/221130-rb30e/
i cant see and oil drain
looks like a series one to me
every n/a block that i've seen that has the provisions for the turbo oil and coolant feed didnt have the oil drain
i wouldnt bet my left nut on it, but i would say its more than likely a series 2
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3903256
yeah its a series one, from memory they had a bung in the side of the sump dont quote me on it,
however it isnt hard to get it put in , the flat round surface at the bottom of the block below where the word nissan is is where you can drill and tap a hole for a 3/4 inch fitting,
while your at it you could have a T fitting put in there so you can have a drain back for a catch can in the future...just thinking ahead.
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3904036
ok im in doubt now, it may be a series one. can you get a better pic of where the oil drain is (if you know) or just a better pic of that same side of the block
^oil return is in the block, its that black area just to the bottom left of the '67S'. for the thread starter, this is what i wanted the pic of, does it have a big square in the midle of it like for a ratchet to fit into?
Edited by VB-
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3904540
thats why i am in some doubt. it has two out of the three holes and yes its missing the oil drain hole. however above the water pump it does have the flat section to bolt the tensioner to that a series 1 does not. that is the part i am more concerned about. drilling and tapping the oil drain hole isnt so much of an issue. its having the area for the tensioner to sit on that i am more concerned about
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3905352
I didn't think that the s1 and s2 were any different above the water pump.
ps. definately series one engine............
I have a s2 in the shed and it has the oil drain in the block ready to go.
its mentioned alot in the major sticky. thats why i was/am concerned.
but i looked at the pdf and did some quick measurements and will have a spot for the tensioner so have started to pull her apart. now awaiting available 26 head.
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3907989
Rb30 e series one and series two.
the only difference i have ever seen(ive owned 10 vl commodores 4 skylines and a patrol) is the drain back for the turbo as described above.
the fact that they are 3 litre blocks mean they ALL HAVE THE FLAT SURFACE ABOVE THE WATERPUMP!.
the water feed and return lines actually travell around the back of the block from the intake side of the engine
similar to that of the rb20det engines
the ports for these are located near the rear heater hose as it exits the block and also the rear of the thermostat housing on the series two or from the block on the series one.
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3909709
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
