GTS-T are 16x6.5" +40 offset and are Cast wheels
GTR are 16x8" +30 offset and are Forged wheels
Both designs are the same just the gtr are stronger being forged and stick out further becuase they are wider and have a lower +offset.
Cast and forged are the way wheels are made. I think cast are just pored into a mold and forged are machined out of a piece of steel. (maybe someone can confirm)being forged is much more expensive and creates a stonger wheel.
Edited by Brokenz
forged are 'cast' under pressure which improves grain alignment and therefore strength. Therefore you need less material for the same overall strength, so it is lighter... forging is different to machined
"billet" is generally used to describe machined wheel pieces, eg 3 piece rim centres may be from billet, ie start with a block of aluminium, use mills to machine to the desired shape.
We need to swap jobs for a while. LOL so i can get some office time and gawk at beauties in suits and you can work in a dirty engineering field :ermm:
Forged is typicall from a machined billet which is then pressed whilst at an elevated temperature to the required shape. Typically more machining follows. So not really similar to casting. Though there are several forms of casting with some better then others.
ahh ok thanks for that. Makes perfect sense. Now while you guys are here :) i'll get you to answer another question for me please :]
16x6.5 ... whats the widest tyre i can get on them without being too dangerous :D 215, 225? or 205 is the widest i can go?
Thanks guys, and thank you optus for providing such an awesome shaped 28.8 bandwidth.
what u are talking about is actually called pressure casting, not forging. forging is exactly that, pressing and forging solid billet alloy. The alloy is often heated up to soften it, and even in some instances to almost a molten form (Semi-Solid Forging patented by SSR) to make it easier to forge. Casting under high pressure can create good results, but it still isnt forging, low pressure casting is used in most cases, especially OE, so id imagine it is what is used for the GTS-t wheels. Obviously then there is gravity casting, u really want to stay away from this at all costs lol. Generally forging is only used for the disk, the rim is usually "flow formed" or "rolled" which is where they heat up the barrel(rim), spin and press the shape. and yeh, then obviously there is the CNC machining to finish it off.
ahh ok thanks for that. Makes perfect sense. Now while you guys are here :( i'll get you to answer another question for me please :]
i personally wouldnt go past a 225, 235 would be the limit tho.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
